Question feed back problem
Discussion in 'DIY Motion Simulator Projects' started by Ayad, Dec 30, 2022.
  1. Ayad
    Ayad Dr.
    surgeon
    Iraq
    - 435Coins
    after I finish and polay some days with 2 24 v motor rig and it was good ,after do another power supply ,my rig start to work funny ,I go back to previous and the rig still has funny work ,the hall sensor work for one side and the other one is not moving even by hand ,the voltemeter read studdy volt 1.79to 1.80 v ,even I use new hall sensor still same I change to 10 k potentiometer it still half and funny jerking movements ,I re i9nstall the arduino ,and change the wire ,this problem still with the annoying static electricity ,even I already isolate the GND of motors ,what is the problem what I should do please any one facing and resolve this problem
    Ayad
    153,986Coins
    +11,162 / 57 / -2
    What control board are you using, perhaps it is faulty.
  3. Ayad
    Ayad Dr.
    surgeon
    Iraq
    - 435Coins
    I use the chinese replica of arduino uno it was working good before with the IBT-2 , I think it some think with static electricity and only the reading from one side is affected when I change the postion the one with problem work well the other is not , by the way am using the screw sheild for arduino ,
  4. Fenton1969
    Fenton1969 New Member
    - 33Coins
    2DOF, AC motor, Arduino
    Som same problem here .i. trying to set things up all is oke
    But once i put the usb cable into the pc the rig starts living its owne live .and no program is running .
    153,986Coins
    +11,162 / 57 / -2
    Something is very wrong, check the hardware and wiring for shorts.
    153,986Coins
    +11,162 / 57 / -2
    I don't knos what your mean by screw shield, can you please elaborate further.
    If using SimTools 2 make sure the PC language is set to English Local: https://www.xsimulator.net/community/faq/simtools-language-setting-bug-change-to-english-local.233/
