My 6 DOF with ODrive
Discussion in 'DIY Motion Simulator Projects' started by Carelsbergh_Stijn, Jan 13, 2019.
  1. PeterW
    PeterW alias Wickie
    Dipl. Ing. Mb (FH)
    1,768Coins
    Hi Stijn,
    Today I will start the second Odrive on my simulator and just ask myself the question how you connected your 3 Odrive to the PC so that all three are recognized independently.
    a) You have named each Odrive differently, e.g. odrv0, odrv1, odrv2
    b) you have used three USB ports and assigned each one to an Odrive.
    c) Somehow different :)
    Actually, I would like to run all three odrive via one USB hub, so that I only use one cable and one USB port.
    Hope you can answer me soon.
    Thanks!
    regards Wickie
    [edit: Solved: doesnt work with USB hub, but with seperat USB connections. In the mover interface erery USB has a separate output window.
    When using Odrivetool they are shown as odrv0 and odrv1.....
    Wickie]
  2. Carelsbergh_Stijn
    Carelsbergh_Stijn Member
    Belgium
    450Coins
    Hi
    My acuators are bldc driven with ODrive.
    They make noise but you can't hear it when playing because the noise of the game is louder.
    Cheers
    Carelsbergh Stijn
  3. Carelsbergh_Stijn
    Belgium
    450Coins
  4. Carelsbergh_Stijn
    Belgium
    450Coins
    Hi
    a) odrivetool does this automatically
    b, c) I used 3 usb ports but you can use a usb hub if you want, a friend of mine uses a hub, it works fine
    Cheers
    Carelsbergh Stijn
  5. Carelsbergh_Stijn
    Belgium
    450Coins
    Hello all
    I've finally gotten around to making a video on the mechanical build process, video on the electrical build process coming soon!
    Please consider subscribing.
    Hope you like the video, if you have a suggestion on another video like a detailed overview of the project, let me know!
    Cheers
    Carelsbergh Stijn
    • Like Like x 5
    • Winner Winner x 3
  6. Carelsbergh_Stijn
    Belgium
    450Coins
    Hello, long time no see.
    I've made a quick video about the electronics case, you can check it out here:
    Cheers
    Carelsbergh Stijn
  7. Carelsbergh_Stijn
    Belgium
    450Coins
  8. Carelsbergh_Stijn
    Belgium
    450Coins
    • Like Like x 5
  9. Carelsbergh_Stijn
    Belgium
    450Coins
    Hello
    I made a video about my complete setup and how everything is connected.
    Hope you learn something. If you have any questions you can ask them here or in the comments.
    Cheers
    Carelsbergh Stijn
  10. Flymen
    Montreal, Canada
    2,462Coins
    DC motor, 6DOF
    Super ton RIG. Good Job
    Eric From Canada ( Québec)
  11. Rolf Bronzwaer
    Rolf Bronzwaer New Member
    34Coins
    hello stine,
    I also live in Belgium and just started my project. Is it possible that I come and see your simulator in person?
    Rolf
  12. Carelsbergh_Stijn
    Belgium
    450Coins
    Hey
    That is possible, but must say that the sim is currently not in working condition. I also have exams at the moment so will have to wait a while.
    Best regards
    Carlsbergh Stijn
  13. Rolf Bronzwaer
    34Coins
    Ok Stijn,
    Thanks for the quick reply. Maybe you can give me your email address and I can give you a picture of my project.
    153,053Coins
    +11,117 / 56 / -2
