Icy7CE
  1. radist07
    radist07 Valeriy
    Учитель
    Россия
    630Coins
    I tried about this recommendation, downloaded and installed the SDK, it still writes a path error SimConnect.dll . I guess I don't understand something. I built the simulator purposefully for Microsoft Flight Simulator 2020
  2. radist07
    radist07 Valeriy
    Учитель
    Россия
    630Coins
    I probably don't understand the English translation correctly
    153,884Coins
    +11,154 / 57 / -2
    Unzip the SimConnect.dll I have attached.
    Then copy and paste it to C:\Users\YourUserName\AppData\Local\SimTools\MFS2020
  4. radist07
    radist07 Valeriy
    Учитель
    Россия
    630Coins
    Thank you very much! I'll try it tomorrow. It's already late at night
  5. radist07
    radist07 Valeriy
    Учитель
    Россия
    630Coins
    Good afternoon, I did as you said but nothing has changed. the error is the same. I guess the problem is that my simulator has been updated to the 40th anniversary version. What do you think?
    153,884Coins
    +11,154 / 57 / -2
    Just to clarify, are you using MSFS, or are you using MSFS 2020, as they are different sims and plugins?
  7. radist07
    radist07 Valeriy
    Учитель
    Россия
    630Coins
    153,884Coins
    +11,154 / 57 / -2
  9. radist07
    radist07 Valeriy
    Учитель
    Россия
    630Coins
    Of course I'll upload the photo as soon as I'm near the simulator. I'm at work now
  10. radist07
    radist07 Valeriy
    Учитель
    Россия
    630Coins
    Good afternoon! Here is a screenshot of my settings
      172.5 KB
      463
      169.8 KB
      428
    153,884Coins
    +11,154 / 57 / -2
    What are your Tuning Center settings, can you please post a picture while the game is running?
  12. Seth Miller
    Seth Miller New Member
    19Coins
    DC motor, Arduino
    I can get msfs to show outputs for gamevibe. And I’ve tuned gamevibe to the correct sound card and changed all the different sounds and such but when I start the game I get no vibes. I can see the data changing with rpm’s and wind noise and gear going up and down but nothin happens with the actual output. I’m using separate output through a pc speaker subwoofer as a poor man’s butt kicker and the feeling is actually pretty cool for testing. I’ve setup the profile and patched and everything shows enabled. Just missing something in between. Thanks in advance!
  13. noorbeast
    153,884Coins
    +11,154 / 57 / -2
    Could you please post pictures of all of your settings, hopefully someone can spot what is going on.
  14. Seth Miller
    19Coins
    DC motor, Arduino
    Ok I figured it out by accident! I just didn’t realize how the workflow was supposed to go. I didn’t know you have to save the highs and lows and then magically it works. Pretty cool software!
  15. Michail
    748Coins
    May someone can me explain what the diff is between roll and roll-rate or pitch and pitch-rate is?
    Do I have to setup extra 1 and extra 2 for the roll and pitch axis too?
    I have a 2dof + TL. so may i can assign yaw to TL axis?
    wich effect is for rolling bumpers on the startlane by start and landing or for turbulance in stormy conditions?
    Thanks and best wishes for 2023 to all of us!
  16. yobuddy
    51,535Coins
    Roll and Pitch are usually just degree outputs.
    So if your on a hill at 20 degrees the sim will be constantly tipped.
    Where roll and pitch rate, output values only while pitch or roll values are changing, therefore its output is the rate of change.
    Hope that helps!
  17. sci666
    1,210Coins
    iiiiii have a problem ..i use the steam version of the game and i can install the patch, Simconnect.dll is copied from the game folder ...everything fine so far... when i execute the "Tool" Simconnect_UDP.exe
    it says (for me in german)
    PAcket rate is set to 100 Hz
    Target IP Adress is 127.0.0.1
    and third row is: open exeption: arythmetic operation overflow ...something like that ?!
    so nothing happened what can i do ????
    its the MS FS 40th anniversary
    https://store.steampowered.com/app/1250410/Microsoft_Flight_Simulator_40th_Anniversary_Edition/
  18. sci666
    1,210Coins
    Sorry. I found out that I simply have to Start the game.... And it works fine. Just one issue... If I pull the joystick the nose of the sim goes down instead of up? Is that normal?
    153,884Coins
    +11,154 / 57 / -2
    Reverse the DIR checkbox settings in Axis Assignments from however you have it set for pitch.
  20. sci666
    1,210Coins
    Yes, but it's Strange because in other games it has correct behaviour
