Question Game Data from Simtools Not passing to Rig
Discussion in 'SimTools DIY Version' started by grog51, Nov 28, 2022.
  1. grog51
    grog51 New Member
    43Coins
    Have spent several days running and debugging code to run motion on rig. All Arduino code works perfectly and all motion functions work in simtools when testing . When you then go to game LFS and start a race rig does not move , leave game and go back to interface setup/axis testing and move all sliders rig does as told. Any ideas appreciated
    153,890Coins
    +11,154 / 57 / -2
  3. grog51
    grog51 New Member
    43Coins
    Thanks noorbeast ,I have completed that step several times in several attempts to get it running. Where are these generated files stored so I can check if they are in fact made. Or have I missed something . Thanks for reply
    153,890Coins
    +11,154 / 57 / -2
    The game generates the files in its game folder.
    My understanding is that you have successfully have SimTools configured and responding in Output Testing, is that correct?
    If so can you please post pictures of all of your settings for LFS.
  5. grog51
    grog51 New Member
    43Coins
    Here is vid will post screen shots soon
  6. grog51
    grog51 New Member
    43Coins
    316347589_552404900040211_8462902001695192112_n.jpg 317291028_657275982742255_1733293259870704815_n.jpg screenshots
    153,890Coins
    +11,154 / 57 / -2
    The video is marked Private, so you will need to change that to Public.
    Looks like you need to capture then refine Min/Max values as game data is present but everything is set to zero:
  8. yobuddy
    51,536Coins
    If you select the Default profile for the game, you should see some Max/Min settings.
    Or while the game is running, click the capture button and after you drive around a bit, click save.
    Take care,
  9. grog51
    grog51 New Member
    43Coins
    Thank you gentlemen for all your help , the beast is alive and now the learning begins :)
