DD-Wheel with Hoverboard Motor
Discussion in 'Direct Drive Wheels' started by Benu, Jan 21, 2019.
  1. Moti
    Moti New Member
    84Coins
    Okay thanks a lot I will take a look at the final cost than if I decide to buy it could you provide the firmware or a place where i can find it?
  2. Moti
    Moti New Member
    84Coins
    Cool!! may i ask where you placed the encoder?
  3. Chris_Beeves
    2,165Coins
    Yeah, if you have a different ppr than standard you have to use the full version.
  4. ZaQ_1
    ZaQ_1 New Member
    51Coins
    Encoder is mounted under the board. I drilled motor shaft and added 3mm rod. Rod is riding in teflon tubing to prevent rubbing on wires. One end of the rod is fixed to motor outer shell, other end is connected to encoder.
  5. felixnelsonsr
    felixnelsonsr New Member
    73Coins
    Link to the firmware and schematic can be found here https://github.com/o-devices/bldc-ffb-wheel
  6. Moti
    Moti New Member
    84Coins
    Oh thats smart!
    Okay I see I can get the full version by contacting him is he still active?
  7. Moti
    Moti New Member
    84Coins
    Oh thanks what is that little breakout board between the Odrive and braking resistor? I assume the 6 pin connector is for his Thrustmaster steering wheel and pedals?
  8. ZaQ_1
    ZaQ_1 New Member
    51Coins
    Its Mosfet board that control power delivered to breaking resistor. It cost ~3$ with shipping
  9. Moti
    Moti New Member
    84Coins
    okay it does not really matter what I use than?
    https://www.aliexpress.com/item/4001100515872.html this one looks the same
    I assume the 40V 50A would be fine?
    and a 50W 2R load resistor would be fine?
  10. ZaQ_1
    ZaQ_1 New Member
    51Coins
    I just readed from wiring picture FR120N and ordered the same.
  11. Moti
    Moti New Member
    84Coins
    okay thanks
  12. Chris_Beeves
    2,165Coins
  13. Chris_Beeves
    2,165Coins
    Yeah, that’s what I did.
  14. Moti
    Moti New Member
    84Coins
    Okay thanks a lot!
    I'm also thinking about the powersupply, I was thinking about a linear powersupply is it true that I don't need a braking resistor if I use a linear powersupply?
    But I think I will still go with a linear powersupply what specs does it need? I will be going for a meanwell powersupply than atleast 12V and how many amps?
  15. felixnelsonsr
    73Coins
    I dont really know about linear power supply but the minimum amps should be like 20 amp in my case i'm using 12v 30A switching power supply
  16. Moti
    Moti New Member
    84Coins
    Oh sorry meant that I'm going for a switching powersupply
    Oh jeez 20 amps?!? Was thinking like 10-12A. Thats also gonna be pretty expensive...
  17. Chris_Beeves
    2,165Coins
    10A will do just fine, the motor won’t take much more than that for very long anyway.
    I use an old computer psu to power mine. Cheap and powerful.
  18. Moti
    Moti New Member
    84Coins
    I got myself some hoverboards but I'm struggling with where to place the rotary encoder. I saw a picture from Roman Smoliakov using an AS5048A or AS5047D but it is not in the supported list on Github.[​IMG]
  19. felixnelsonsr
    73Coins
    Well it's kinda depend on how much you care about aesthetic for me i dont really care so I just hot glue the encoder on the motor mount It's look crappy i know But hey it's work and that's the point right? LOL
  20. Moti
    Moti New Member
    84Coins
    Yeah I do kinda care about the looks but I think I found a solution just using some pulleys and a belt. I ordered the parts just need to wait for them to arrive.
