FlyPT Mover 3.5.3
  1. hexpod
    hexpod http://heXpod.xyz
    berlin
    7,783Coins
    DC motor, 6DOF
    3,6 has a complex math for transitional exit from e singularity position which @pmvcda developed.
    It could be he didn’t published it because he didn’t judged this build safe enough. I don’t know the exact reason.
    If you want I can share it for experimental purpose. You use it at your own risk.
  2. Nick Clements
    Nick Clements Member
    95Coins
    2DOF, 3DOF, DC motor, SCN5, Arduino, Motion platform
    Happy to give it try if you don’t mind sharing.
  3. hexpod
    berlin
    7,783Coins
    DC motor, 6DOF
    There is still some issues (some minor bugs like triggering sources and transitions missing when data starts/stops to flow. It can still kick hard)
  4. Nick Clements
    95Coins
    Thanks for the offer , but I don’t think my rig would like being kicked hard, especially at this early stage. I’ll stick with the stable version for now.
  5. DerKlausi
    DerKlausi New Member
    117Coins
    Hi all,
    I'm pretty new to FlyPT and currently trying to get my DOF-Reality P6 working with it. I'm using the 6DOF rotating hexapod as RIG and so far got all axes working properly.
    Now there's one issue: as soon as I activate a POSE in RIG, even if it is a blank one with all default values, actuators (that is, motors) number 4 and 6 will instantly jump to a position at roughly half of the max.
    negative range as displayed in RIG under "Actuator position test". All remaining 4 motors are staying at zero (level position) as expected. As soon as I uncheck the POSE in RIG, motors 4 & 6 will jump back to level position.
    Any ideas what could be the reason of this behaviour are much appreciated!
    Cheers,
    DK
  6. pmvcda
    15,666Coins
    Please share the build you have.
    In reality I made changes to it and did not keep that one.
    Current one I have is not working and is not safe at all.
    Althought that one is not 100%, it's an upgrade.
  7. GWiz
    GWiz Active Member
    Dentist
    Aberdeenshire, Scotland
    1,509Coins
    I also use a DOFReality P6 and have FlyPT setup to work with it. My P6 is an older one from 2020 with the old firmware and older style gearboxes and motors on it so this might not work for you, but I've attached my mover file for you to try as a starting point.
  8. jdmkun
    jdmkun New Member
    6Coins
    Motion platform, 6DOF
    Hello fellow simmers,
    I am using FlyPT with a 3DOF SFX-100 rig along with a NLR V3 seat mover. I primarily fly helicopters in MSFS 2020 in VR. The combination of the actuators with the seat mover work really well for me while in the air. I also get a nice landing effect. I am also using Sim Racing Studio. The biggest challenge I've tried to figure out, but can't, is getting a feeling of weightlessness at takeoff or the feeling of a hover. I'm hoping that the next release of MSFS 2020 will fix the telemetry data for helicopters. In the meantime, has anyone had any luck with creating that feeling of momentary weightlessness (or in helicopter talk, light on the skids)? Would the Pose motion be on the ground or in the air? I've been playing with both.
  9. DerKlausi
    117Coins
    Thanks a lot, very much appreciated!
    I tried your file and after re-arranging actuator assignments and correcting inversions, all basic poses appear to be working. It seems the offset I described in my previous post had been caused by the wrong vert. angle settings.
    Now what's currently happening is that I'm running into singularities even though I'm well within the rig's physical limits, but I assume this could be due to wrong geometry parameters as well. I'll keep on toying...
    Cheers,
    DK
  10. hexpod
    berlin
    7,783Coins
    DC motor, 6DOF
    After having a nice dinner with @Dirty, he advised one clever thing which he’s using in his software. In fact, it could be that the majority of nasty kicks appearing when data flow starts/stops, comes from vertical accel having a value +10. he overcomes this issue by making standard values 10,0,0 (vertical, lateral, longitudinal).
    Knowing that not many car games are using 10m/ss, would it be possible to set such a « standard » at least for all flying titles and avoid this vertical kick ?
  11. hexpod
    berlin
    7,783Coins
    DC motor, 6DOF
  12. hexpod
    berlin
    7,783Coins
    DC motor, 6DOF
    Maybe you could implement a mechanism which detects when the data stops to flow and apply a transition. (Or it is already there but got broken)
    Thank you very much for all efforts
  13. Ari_Sväng
    Ari_Sväng New Member
    43Coins
    I have driven with my simulator for a little while now, but now I have a problem with it. Mover shows that UI latency is sometimes almost 200ms and the simulator is really jerky. I found some old posts with same kind of problems, but I didn´t found why that happened.
    It is possible that FlyPT isn´t the main reason for my problem, because my CPU uses about 70 - 85% of it´s capacity when I am driving Dirt Rally 2.0 or Assetto Corsa and the FlyPT is on. My PC is the same than week ago when everything was working. Before when everything was working, I never checked CPU usage, so I don´t know was it the same 70 - 85%. I also didn´t checked UI latency so I don´t know what is normal level.
    I made my setup for Dirt with FlyPT tutorial video from youtube, so I don´t have any wierd filterings which could slow down.
    I am really novice with PC´s so good advices could be useful. Do you have any idea could the FlyPT cause the problem or where should I start looking?
    Br,
    Ari
  14. sallerding
    sallerding Member
    Perth, Western Australia
    344Coins
    I w
    I suggest that you add some filters to prevent the jerky movements. Trying to work out what filters works from scratch is difficult. So I would test some flypt profiles from the online repository when in flypt and find one for your rig type and dirt, and see what works and refine from there.
  15. hexpod
    berlin
    7,783Coins
    DC motor, 6DOF
    Phyphox experiment realised 2 m below pilot's head. (I guess). Cross-reference data for eventual comparison with motion simulator
  16. smitty
    smitty Active Member
    936Coins
    oh man thats a bummer, i use voicemeeter to make my vr headset not freak out MSFS when its usb's power up
  17. deadlymanager
    deadlymanager Member
    10Coins
    FlyPT 3.5.3 (12 09 2021) and WIP 3.6.0 what the problem? I can't launch. Nothing after run. 3.5.3 without upgrade working, but after start show me 2 errors, I ignore it and all fine.
  18. digitalmonk
    digitalmonk Member Gold Contributor
    Canada
    239Coins
    Does anyone know if F1 2022 will work with the f1 2020 source? There is no direct game source for it.
    How are the game sources added in? I'm assuming Pedro has to update the release to include it?
  19. Chipless
    Chipless Member
    146Coins
    I am at a cross-roads with my sim rig potentially adding some additional motion cues, and I need to make a decision about controlling my four SFX-100 actuators via a Thanos controller: Should I stick with Sim Racing Studio (SRS), or switch to FlyPT Mover? I only use the SFX-100 actuators for heave, roll, and pitch effects (e.g. I don't attempt to use them to simulate sway, surge, or traction loss). Does anyone have experience switching from SRS to FlyPT or vice versa? I am hesitant to lose some of the haptics that SRS offers, but I don't know if I would gain something with FlyPT that would make that loss worth it. Thanks for any info you can spare!
  20. zhai1987
    zhai1987 Member
    320Coins
    2DOF, 3DOF, AC motor
    The same goes for mine. Why? Does anyone know?
