Compact 3dof build series arudino IBT-2 12v server ps.
Discussion in 'DIY Motion Simulator Projects' started by Halloween2go, Sep 9, 2022.
  1. Halloween2go
    Halloween2go Active Member Gold Contributor
    1,395Coins
    Hello guys.. Trying to tackle a new build here. so decided to put it on youtube too. compact 2 dof plus traction loss. Going to use the 12v crab pot pullers, hall effect pots, arduino and either dell or hp server power supplies on this one. this is episode #2.. i'm in the middle of this build so i will post up the dimensions etc soon.. DMAX
  2. Rav3n87
    Rav3n87 Active Member
    723Coins
    Hey Dave,
    Loving the content so far on your channel!!!!
    I've been watching your channel from the first sim you made and i was going to try and make the 1st one, But this new design has made me change my mind!! how do you think it will compare?
    Can't wait for you to post the dimensions!
    I'm just waiting for my new fixed back seat to arrive, and picking the last of the materials later this week to get started,
    i have the 25:1 worm drives from motion dynamics I'm hoping they will be ok for a more compact config, my control system is built and ready to go, Eagerly waiting for episode #4!
    Thanks for the inspiration Dave!
  3. Nicki9knuckles
    Nicki9knuckles Active Member
    Web Developer
    794Coins
    Hey Dave, thanks for all your awesome content, its been super helpful. I am following your progress and making my rig along with you. I have basiclly bought all the same stuff you have for your first rig, the 3 crab pot motors, the same hall effect pots, the same motor controllers.
    I am starting the wiring now. I bought a 600 W power supply i am going to attempt to use on all 3 motors. How are you planning on powering this new rig? Using the truck motor again?
    Thanks Dave!
  4. Rav3n87
    723Coins
    Hey Dave,
    Eagerly waiting for the next video!
    I got stuck into it yesterday afternoon and I've managed to catch up to were you are haha
    Keep up the great work!!!!
    Cheers
    Dave
  5. Halloween2go
    1,395Coins
    Looking very cool.. I'm going to be painting my frames this time!!
  6. Halloween2go
    1,395Coins
    EP 2,3 and 4 are up on the YT site..
    Here is Episode 5.. probably my best one yet.. Upper frame and seat..
  7. Rav3n87
    723Coins
    Yayyyyy, Looking good Dave!!! Looking forward to next one, Will be up to your point again hopefully on the weekend, Seat frame will be moderately different though
    Cheers
  8. Halloween2go
    1,395Coins
    Posted this video on my channel - how to add traction loss to the DIY motion simulator 3DOF compact motion simulator for Direct Drive wheelbases. Take a look if you have time.. DMAX
  9. Rav3n87
    723Coins
    YESSSSS
    More things i can do!!! Keep it coming Dave! Lovin it
  10. Halloween2go
    1,395Coins
    Episode 7 of DIY 3DOF motion sim build - compact motion sim.. mounting the motors and U joint etc.. take a look if you guys have time.. Thanks DMAX
  11. Halloween2go
    1,395Coins
    Ok guys.. Dustin (thanks my friend) allowing me to give away a few copies of simtools pro for 2023.. Here is the first 'drawing' winner.. Still building a compact 48" 3DOF motion sim - this is episode 9.. Tune into the channel if you have time..
  12. Halloween2go
    1,395Coins
    two photos from this weekend.. Getting a bit heavier now..
  13. Halloween2go
    1,395Coins
    I made a video on finding the CENTER OF BALANCE and some other stuff.. Check it out if you guys have time.. it's on YT..
  14. Halloween2go
    1,395Coins
    Ok.. decided to have a little fun with the simulator. made a video showing it moving take a look if you have time.. Thanks DMAX
  15. Dropkicks17
    Dropkicks17 Member
    USA
    148Coins
    Looks good Dave. I watched your latest video during my lunch break. I made my rig by closely following your videos for ideas and inspiration so thanks for your many contributions! I got mine working this week and I am enjoying it so much!
  16. Halloween2go
    1,395Coins
    That's fantastic! yeah its so cool once it starts moving with the game telemetry.. Thank you for letting me know! DMAX
  17. brandon hager
    brandon hager New Member
    Springfield MO
    71Coins
    i been watching your videos for a while and this week i start to build my own 3dof. completely off of your build plans. just want to say thanks for all the info you have given over the time that you have been doing this.
  18. brandon hager
    Springfield MO
    71Coins
    also is there a discord?
  19. Halloween2go
    1,395Coins
    Starting to re-assemble the new 3dof rig. Also getting weight measurments and comparisons between the old rig and this new COMPACT rig. and wire management. Take a look if you have time Thanks Dave
    • Friendly Friendly x 2
    153,914Coins
    +11,154 / 57 / -2
    In terms of easily disconnectable wiring tips, I used 2 X 9 pin trailer plugs, a combined 3.5mm audio and USB plug, plus a cigarette style 12V connector plug to connect a plethora of things to my compact rig, with everything else in a separate box that the PC sits on:[​IMG] power a
