OpenVR-MotionCompensation
Discussion in 'VR Headsets and Sim Gaming - Virtual Reality' started by Dschadu, Apr 19, 2020.
  1. Michael Mariacher
    Michael Mariacher Member
    632Coins
    4DOF
    Hi all,
    I'm wondering, if I'm the only one facing some OVRMC 0.3.6 issues since some weeks.
    0.3.6 was working flawless for months, I almost never had to restart Steam VR to get OVRMC runnig.
    But around July 11th OVRMC suddenly did not start anymore. After de- and re-installing OVRMC and Steam VR I did not got any huge difference.
    Steam VR crashes quite often and I need to restart SteamVR several times, incl. unblocking OVRMC.
    Sometimes it looks like having OBS Studio running help, but I think this is more or less placebo. It does not work all the time, so maybe by chance only.
    Most of the time a re-start after unblocking OVRMC brings the OVRMC logo in, but clicking on it leads only to an "empty" OVRMC config page.
    I tried SteamVR in and out of Beta Mode, no difference.
    1) Typical 1st startup page without OVRMC logo
    2) Nothing blocked at first startup
    3) Restarting and crash
    4) Unblocking and restart bring up sometimes logo but "empty" OVRMC config page
    Info:
    Windows 10 Ver 21H2 Build 19044.1826
    Steam VR Build ID: 9124143 July 18th 2022
    OVRMC 0.3.6
    Any idea what could be wrong?
    Michael
  2. sberns
    sberns Member Gold Contributor
    432Coins
    3DOF, SCN5, Arduino
    Same here
  3. Michael Mariacher
    632Coins
    4DOF
    Right after posting, SteamVR made an update and OVRMC started 3 times right from beginning. I'keep you updated if this is the fix or just another stroke of luck. Time will tell
  4. Michael Mariacher
    632Coins
    4DOF
    Update - seems to be solved with latest SteamVR update.
    Since updated to Steam VR Build ID: 8855498 July 28th 2022 OVRMC runs as flawless as before.
    Michael
  5. Payokvati
    Payokvati New Member
    43Coins
    Wont work flawlessly for me. I have to fight with the program for about 2 hours everytime before it kind of works. If im Lucky. Same problems as you, but mine did not go away after update :( i have varjo aero headset. I dont know if thats the problem. But i had some similar issues with the index. Just way worse now.
  6. Michael Mariacher
    632Coins
    4DOF
    Oh, sad to hear. After re-installing SteamVR, OVRMC 0.3.6 and the update of SteamVR it's now really running well. Not a single restart required since then. Vive Pro
    I will report if I need to restart to get it runnnig.
    Michael
  7. kparkin
    kparkin Member
    United Kingdom
    236Coins
    4DOF
    There is definitely an issue with Varjo and steamvr that interferes with OVRMC. It is very hit and miss to get it working.
  8. fabioflyer
    fabioflyer New Member
    102Coins
    Motion platform
    i have the same problem with steamvr beta and the hp reverb g2, most of the time the dashboard won't open and many times steam vr crashes, any hint?
  9. kparkin
    kparkin Member
    United Kingdom
    236Coins
    4DOF
    Have you tried with non-beta steamvr?
  10. misoswan
    misoswan Active Member
    1,032Coins
    3DOF, Arduino, JRK
    hello try to run on openxp
  11. fabioflyer
    102Coins
    Motion platform
    yes and if it worked at first now seems no joy....
  12. Wagnard
    Wagnardsoft
    Canada, Quebec, Mirabel
    5,027Coins
    I have potentially fixed the problem with the recent SteamVR version, try replacing the motioncompensation driver Dll with this one. The location is usually your steam/steamapp/steamvr/driver/00vr.../bin/win64
    Let me know if it helped.
  13. sallerding
    sallerding Member
    Perth, Western Australia
    344Coins
    Thx very much. That updated .dll now works perfectly whereas before I couldn’t get the cog to show in steamvr settings with the old version
  14. Michael Mariacher
    632Coins
    4DOF
    @Wagnard - Thanks, you are my hero.... :thumbs
    Fully fixed the issue for me.
    1) Switching back to "non-beta" version
    2) Updating SteamVR to latest version (9276252)
    3) Starting steam and check if OVRMC will start - it did
    4) Doing some test runs with AMS2 - all good
    hug:
    Michael
  15. fabioflyer
    102Coins
    Motion platform
    thanks a lot it helped!!!
    now it works all the times!
    Fabio
  16. tadek
    tadek Active Member
    548Coins
    hi
    I have trouble resetting a position.
    i have pimax
    I am using pitool abd open xr mixed reality.
    reset work in normal but don't work with mixed reality
    please help:sos
    best regards
    tadak
  17. Wagnard
    Wagnardsoft
    5,027Coins
    Just to let everyone know that v0.3.7 has been officially released and it contains my fixed dll.
  18. Marco Annunziata
    865Coins
    Hello, there is someone who has a problem with OVRMC, if I put a controller as a reference tracker and doing pitch and roll, from SteamVR View perspective it's all ok but from HMD perspective I see different behavior. Is there any option in SteamVR to fix this or is HMD setting option? P.S. I'm trying with Pimax 5k and Quest 2 and I'm having this issue with both HMD.
    Here is what I get rotating the tracker with the hand.
    Thank you in advance
  19. Wagnard
    Wagnardsoft
    5,027Coins
    I can see a similar issue with a Reverb G2 (mixed reality) and it was because of the Windows Mixed Reality for SteamVR driver. Reverting to the LKG version in Steam Fixed it.
    Maybe it's a similar issue on your end.
  20. Wagnard
    Wagnardsoft
    5,027Coins
    Its for Windows mixed reality, you have pimax, normally you don't have that.
    Its when I click property on the windows mixed reality in steam and under beta, I select the LGK version
