luu trung's project
Discussion in 'DIY Motion Simulator Projects' started by luu trung, Apr 21, 2022.
  1. noorbeast
    153,824Coins
    +11,150 / 57 / -2
    Looks like Motors 1 and 2 are Off and Motor 3 On.
    I am not sure I know what you mean, can you please explain further? Are you having difficulty navigating the LFS game menus, or setting LFS up for motion?
    You do need to run LFS before patching it for motion: https://www.xsimulator.net/communit...run-in-first-person-mode-before-patching.365/
  2. luu trung
    luu trung Member
    172Coins
    -if 3 motors have such cardan joints in the article, will there be axis "heavy" in simtool? 3 motors will not be able to go up and down at the same time.
    -i am testing 1 spring inner core has damaged no oil inside to go up and down gently but the upper iron frame is tilted by rotuyn joints. Should I try 4 cores mounted below the cardan joint?
    - I use Google translate. hope you will understand
  3. luu trung
    luu trung Member
    172Coins
    1 axis will not hold the frame above it will tilt
  4. luu trung
    luu trung Member
    172Coins
    the picture below doesn't have a cardan joint in the middle. why doesn't the upper frame fall??
    153,824Coins
    +11,150 / 57 / -2
    The motors and gear ratio are adequate to the design task.
    By that I mean the motors can't be back driven when unpowered, that means the gear ratio is such that the motors can't be rotated when unpowered.
    The motors also have to be adequately powerful to dive the rig under load.
  6. luu trung
    luu trung Member
    172Coins
    when i click turn on of output testing i hear beep beep sound???
    153,824Coins
    +11,150 / 57 / -2
    Is it a USB disconnect or something else?
    Perhaps use Event Viewer to check the Windows event logs.
  8. luu trung
    luu trung Member
    172Coins
    -game manager connect but I don't know how to start LFS game.
    -I watched youtube for instructions on copying the API plugin file to the place where LFS is installed
    -why I don't see the plugin API.dll file in simtool
    153,824Coins
    +11,150 / 57 / -2
    LFS must be run before it is patched for motion: https://www.xsimulator.net/communit...run-in-first-person-mode-before-patching.365/
    The fully functional LFS plugin is packaged with Simtools, specifically for testing purposes, you don't need to do anything else.
  10. luu trung
    luu trung Member
    172Coins
    hi. can the arduino circuit connect to 4 ibt 2 circuits. if not can i get the output signal of arduino connect 2 circuits and 2 motors in parallel
    for example
    motor 3 and 4 will work the same from 1 arduino signal port
