Searching on how a programmed ride
Discussion in 'Force-Profiler Simulator Control' started by Zedian, Mar 14, 2010.
  1. Zedian
    Zedian New Member
    0Coins
    Dear Folks:
    I was just looking in the forum but didn´t find anything related to use XSim to build a motion simulator with a pre programmed ride, I´m looking info about the capabilities of XSim for my purpose as about the hardware needed since i live in Mexico.
    Any help would be appreciatted Thanks.
    Zedian
  2. egoexpress
    egoexpress Active Member
    Germany - Frankfurt/M
    422Coins
    The XSim Video-Plugin is what you need for a programmed ride.
    You can either assign the movements manually, or you can use pre captured g-force data.
    The following example made by MboRacing uses data which has been captured via an DIY accellerometer during the race.
    http://www.youtube.com/watch?v=oexCGDykdVI
    regards
