Blue Tiger Eleetus Motion Platform
Discussion in 'Commercial Simulators and Peripherie' started by Dello, Jan 11, 2022.
  1. Dello
    Dello New Member
    91Coins
    Hi
    I own an bluetiger motion platform and work with their own software with MSFS2020, P3D, X-plane11, Dirt, DCS, Assetto..., project cars
    For simulation like Eurpean truck simator 2, automobilista and IL2 i plan to use simtools 2.
    Did my motion chair can work with simtools version 2 via UDP
    I need to check, beforce I oder an license and plugins
    Thanks for help !
    152,177Coins
    +11,063 / 56 / -2
    Your question should be directed to Eleetus, as the core question is specifically how their rigs communicate with whatever hardware and controllers they use.
    SimTools can be used with a very wide range of hardware, but it must know how to communicate with that hardware and some commercial entities, particularly those with their own control software, do not always make that information available.
  3. Dello
    Dello New Member
    91Coins
    th‘x for your answer. The bluetiger platform react when I use the net with 127.0.0.1 and port 55556, but I platform move at test button directly to the back left. I don‘t know how I should address the axis and the right figures for them in the settings.
    Maybe some one van help me. This would be great. I‘m pretty sure that this brilliant simtool software is able to work with my motion platform.
    Maybe there exist a way to get this out step by step
    Regards
    Gerd
    152,177Coins
    +11,063 / 56 / -2
    What manual or information do you have about the rig hardware and its configuration, as that may help?
  5. Dello
    Dello New Member
    91Coins
    Dear noorbeast
    th'x for your request. attached you will get some pictures from my rig. As i think it is a 2DOF with totating actuators with a central moving point. But i ask the manufactorer -now Eleetus - to look for some more technical data. Wilson bates is my contact in that company. He already adressed his interest to step into our conversation at this forum, because this is in the benefit for the community at. I also try to use the free platform FlyPTmover but come to the same result, with the setting 127.0.0.1 and port 55556, that the rig only move to the back left position. With port 55557 , which i also can usde for dirt game, the rig come in a horrible shaking condition. i also added some text files for settings of my rig.
    For the setting of the BlueTiger Utiliy I use IP adress 10.0.0.100 Subnet Mask 255.255.255.0
    Default gateway is 1.0.0.0
    I hope this will make the situation more transparent. As soon i get some more infos i will send these or Wilson Bates from Eleetus will step into our conversation, too
    take care Gerd
    152,177Coins
    +11,063 / 56 / -2
  7. Dello
    Dello New Member
    91Coins
    Dear norbeast,
    no, the physical output test brought with port 55556 the rig in the back left position and with port 55557 a horrible shaking. I simply did not know what parameters in need to put in the two axes at simtools and I need help!
    TH‘x in advance
    Reg
    Gerd
    152,177Coins
    +11,063 / 56 / -2
    This is not just a question of what port is used, but the what format the data is to communicate with the hardware controller(s).
    I don't know if the SimTools dev @yobuddy has any historical experience with bluetiger motion rigs, but I am sure he would be willing to help out interfacing those if the company is willing to detail data communication requirements.
  9. Dello
    Dello New Member
    91Coins
    Dear noorbeast
    I already contacted Wilson Bales from Bluetiger / Eleetus in regard to this request.
  10. Terrell minor
    Terrell minor New Member
    35Coins
    2DOF, 3DOF, Motion platform
    Hey did u ever get your bluetiger to work ? I have one and i cant seem to get mine to work either
    152,177Coins
    +11,063 / 56 / -2
    See my previous comment, it is really a question of the company providing information about how to communicate with the rig:
  12. Terrell minor
    35Coins
    So do u know away to get some info on this rig buddy ? Thanks
  13. noorbeast
    152,177Coins
    +11,063 / 56 / -2
    Try approaching the manufacturers, you never know, they may be wiling to provide the required information.
  14. Clive Allen
    Clive Allen New Member
    22Coins
    Hi Dello, did you ever get your Blue Tiger to work with Simtools 2, I'm trying to get ours to work with MSFS2024. Did you have any success.
    152,177Coins
    +11,063 / 56 / -2
    Just so you know @Dello has not been active since the start of 2024.
