FlyPT Mover 3.5.3
  1. Deleted member 38270
    hi
    TOPIC : DCS
    I have a problem with putting a pose.
    I would like to add the stall speed of the plane in DCS.
    So that at speeds below 270 km / h
    there were vibrations.
    Nice as if the vibrations build up as the speed decreases.
    Thank you and best regards
  2. Roller2525
    Roller2525 Member
    220Coins
    Hi guys. Can RWASH be used with acceleration? I am wanting to replicate accurate motion cueing effects as seen in this video..
  3. Trigen
    Trigen Active Member
    2,884Coins
    The stall value works for some planes (i think) but i find POSE from noise generated from value (speed could work) and use a LSPLINE or CSPLINE filter works well to add noise. Easy to configure as you can set the points and have it to 0 for speeds above 270. I just use it for AOA and panel shake on my Viper though
  4. Deleted member 38270
    Thank you Trigen
    Super will try..
    How did you get your AOA value?
    Best regards
  5. bruno1210
    bruno1210 schumi06
    103Coins
    Hello, I can not configure my arduino uno + saberthoot + 12v motor on flymover the game telemetry works but not the motors the problem comes from the output impossible to understand if a person can help thank you just showed me a picture of its setting output thank you .
      245.8 KB
      305
  6. Trigen
    2,884Coins
  7. bruno1210
    bruno1210 schumi06
    103Coins
    Hello, a big thank you to all for not helping me on a little question for the adjustment of the output I always help on the forum but hey ..........
  8. Skuldi
    Skuldi Member Gold Contributor
    Germany NRW
    265Coins
    @pmvcda: Is there a way to get rid of this random kicks in shooting strength in IL 2?
  9. Deleted member 38270
    hi Trigen :thumbs
    Thank you very much great tip.
    I cannot find AOA on my FlyPT version.
    Which version are you using?
    What kind of plug do you use for DCS?
    Thank you very much and best regards
  10. pmvcda
    15,478Coins
    Well, sorry for having a life outside of this...
    Now let's put it working.
    I don't know the settings used in Simtools to connect with Uno and Sabertooth.
    Never used them.
    Show here what you use in SimTools (get a screenshot).
    The settings in Mover should be the same.
    I think you told me that it was working on SimTools.
  11. pmvcda
    15,478Coins
    AOA in DCS should be on the latest version... I think.
    I'm a bit confused with my work builds.
    To get it you need to update the Lua file to the latest one included in the download.
  12. pmvcda
    15,478Coins
    I have the idea there was something strange about the data in IL2.
    They don't give us a reference about it. It was all try and error.
    Will take a look again.
    I think there was some values showing intermitentlly in the data causing the data location to change in the end.
    And shooting info was at the end of the data from what I remember.
    I will look at it.
  13. pmvcda
    15,478Coins
    RWASH is made for position, not speed or acceleration.
    To wash the acceleration you need to use a high pass filter.
  14. pmvcda
    15,478Coins
    Ok just saw this post.
    Try to increase the interval loops to 2 or 3 (in the output).
    Also make sure the rig is setup with 10 bits on the actuators.
    Just the output does nothing, you need a source, a pose and a rig to generate actuators.
    With actuators, you can select them in the output.
    From that image, there's no <Axis1a>. You don't have actuators set.
    Post here the setup file so I can take a look and see what is missing.
  15. bruno1210
    bruno1210 schumi06
    103Coins
    Hello, please help here is the file I have an arduino with a code for simtools and a saberthoot for f1 2021 dx12
  16. Roller2525
    Roller2525 Member
    220Coins
    Anybody have a good DCS profile I could try?
  17. pmvcda
    15,478Coins
    Try with this:
    The file you posted had the lines swapped and you where sending a strange string.
    Please try and see if you get some motion.
  18. bruno1210
    bruno1210 schumi06
    103Coins
    I have impeccable movement at 6 I will test the effects a big thank you
  19. Fredo187
    Fredo187 New Member
    24Coins
    I have a problem with using transducers. All my audio sources have only 2 channels. I checked my windows settings and all my audio sources have their channels correctly configured.
    However, it works on my first 2 channels but i can't use my third transducer.
    152,553Coins
    +11,087 / 56 / -2
    You can use very cheap USB sound cards for managing multiple transducers: https://www.ebay.com/itm/274125100662?hash=item3fd3211676:g:eKMAAOSwu-teZtpw
