3 DOF / 3x Mixed Vertical Actuators 24v 200w / adjustable rig / Done and runing :D
Discussion in 'DIY Motion Simulator Projects' started by seuszok, Nov 14, 2021.
  1. seuszok
    Poland
    477Coins
    Hello all
    I started thinking about the simulator after encountering structures based on wiper motors. Due to the fact that I do not want to build the simulator twice, I turned to a heavier structure based on 3 electric motors with the elimination of the lower frame.
    So I thought about lever driven linear actuators, their characteristics will not be linear but I had carriages and rails after cnc plasma construction and the ball screws are out of range.
    Moving on to the point (secondary market):
    - I bought 2 motors about 200W 24V (I'm looking for the third one)
    - INA KWVE20B rails and trolleys
    - aluminum profiles 40x80,40x40
    - bucket seat
    I modeled the drive mechanism (below its 3rd configuration :)
    I have initially assumed the frame size of 1200x600mm
    Motors located on the outer contour, rear ones will be in mirror but I was not waste time for that now.
    Actuators arre not finished, plates need be stronger on the back and will be installed on profiles by using 2 surfaces.
    some weeks later:
    Updates (12 2021) all information bellow
    -1 motors with gearbox
    -2 motor with one gear
    -arduino uno, 3x BTS7960, 3x AS5600 hall + housing printed 3d, dc power 10A and 20A
    -G29 whell,mod pedalls, gear knob
    -aluminum profiles 45x90,40x40 (frame 1200x700)
    Update (03012022)
    need to add 2 parallel ibt-2 for each motor
    add 2nd arduino to drive 3rd motor
    motor tested smc3 and front spring on monitor support
    add hanbrake and separate g29 pedals connection
    Update (08012022)
    rig is runing
    front need 2nd ibt-2
    still have some isuess (details during thread)
    movie below
    I just receive DIY KEY from SIMTOOLS
    Some movies:
    https://www.bitchute.com/video/UQ470ENrmbKe/
    Update (22012022)
    https://www.bitchute.com/video/Icsw8mWBu3Nz/
    Update (27012022)
    instal galvanic isolation ADUM3160 for arduinos (motor drivers)
    instal cooling for motors and BTS7960
    instal second keyboard , mouse and watt usage measurement
    need to:
    instal rumble motors for traction lose
    some safety shields for rear mechanics
    change drivers cable for IDC-10 tape
    Update (21022022)
    Change rear levers from 50 to 35mm (motors hot)
    Change arduinos from ch340 to 16u2 (lost motion in game)
    Add arduino schields and change drivers cable for IDC-10 tape
    connect all grounds
      34.8 KB
      448
      30.9 KB
      446
      23.7 KB
      466
      24.1 KB
      469
      24.6 KB
      439
      69.4 KB
      2,160
    • Like Like x 8
  2. seuszok
    Poland
    477Coins
    Design is little bit change. Previous plate was too huge.
    Now, device was build on two plates is more compact.
    Stroke is some 70mm or 100mm.
      51.3 KB
      413
      46.1 KB
      432
      47 KB
      412
      75.1 KB
      1,834
      54.3 KB
      423
      34.1 KB
      398
      65.5 KB
      418
      50.8 KB
      408
  3. Gadget999
    12,359Coins
    I like your vertical actuators - they look neat
    However there is no advantage over a fixed base and lever arms
    Have you built the actuators yet ?
  4. Gadget999
    12,359Coins
    Google - scotch yoke mechanism
  5. seuszok
    Poland
    477Coins
    Tomorrow I will finish the details and check if the boards fit in the mirror so as not to multiply the drawings for milling. the profile visible in the picture is the right part of the frame. We will see if that assembly will work :)
  6. ahoenksiluman
    ahoenksiluman Member
    indonesia
    89Coins
    good design mate, it can be compact, dont need lower chasis like conventional design...
  7. seuszok
    Poland
    477Coins
    Due to the fact that the aftermarket is not the supermarket ,plan is changes and requires redesign.
    I did not have access to the seat models, so I failed to measure the dimensions to prevent collisions (photo 10b, 23b)
    I changed the profiles, based on the assumption of 40x80, to 45x90. frame extended by 100mm (1200x700).
    This change requires a redesign of the engine mounting plates. (photo 11b-16b)
    The next engines that I was able to buy have a different design than the previous ones ... should be more reactive, they will be mounted at the rear (photo 11b, 12b)
    As potentiometers for motors, I wanted to use a ten-turn potentiometer and connect the motor shaft with a printed gear in the proportion of 1/16, which was to use 8 turns of the potentiometer for half the shaft.
    I have printed the samples, but there is no possibility for the gear to fast run potentiometer (hevy to fast rotate) - too low teeth (increasing the height of the teeth does not make sense because it allowed the entire structure to go away from room :) (21b)
    A colleague gave me the idea of replacing the potentiometer with the AS5600 hall sensor as a module:
    https://kamami.pl/enkodery/580650-modul-enkodera-magnetycznej-z-ukladem-as5600.html
    And another thing that needed improvement was the floating feet.
    When changing the geometry during the movement with the maximum tilt - the foot moves more than 8mm. (photo 19b, 20b)
    The feet are supposed to have 10mm of play (photos 17b, 18b).
      31.3 KB
      480
      16.2 KB
      478
      15.3 KB
      465
      22.2 KB
      451
      33.9 KB
      452
      30.8 KB
      439
      31.1 KB
      467
      9.6 KB
      483
      16.4 KB
      455
      17 KB
      453
      7.7 KB
      439
      314.4 KB
      449
      262.9 KB
      465
      219.4 KB
      459
  8. seuszok
    Poland
    477Coins
    Some progress in garage to share :)
      242.7 KB
      436
      245.6 KB
      432
      177.1 KB
      434
      260.3 KB
      432
      232.1 KB
      443
      252.3 KB
      440
      200 KB
      423
      213.2 KB
      456
  9. seuszok
    Poland
    477Coins
    The pedals will be mounted upside down so I changed the throttle and clutch mechanisms
      223.3 KB
      356
      199.6 KB
      369
      182.8 KB
      360
      199.5 KB
      369
      257.7 KB
      363
  10. seuszok
    Poland
    477Coins
    After mounting the steering wheel, pedals and gear knob - I checked my hidden plan.
    The system can be configured to be close to f1 or a normal car. Joints and locks serve this purpose. It is enough to mark the places on the profiles and secure the positions. I have to say that it looks promising. Both positions are ergonomic, but we'll see in motion.
      255.5 KB
      1,778
      245 KB
      1,671
      256.2 KB
      369
      263.3 KB
      352
      209.8 KB
      377
      194.1 KB
      329
  11. seuszok
    Poland
    477Coins
    This week is drawing and printing.
    Installation of the hall sensor AS5600 using printed elements as below. White is prototypes and improved fits.
    Ender printer: 0.2 nozzle / 0.1 layer / temp 200 / speed 150 / wall 1.5 / filling 20 / PLA material
      257.2 KB
      386
      258.2 KB
      381
      117.5 KB
      373
      105.4 KB
      390
      111.4 KB
      395
      35.1 KB
      401
      34.2 KB
      406
      27.4 KB
      382
      56.4 KB
      384
      241.3 KB
      399
      173.7 KB
      393
      204.6 KB
      406
      210.4 KB
      398
  12. seuszok
    Poland
    477Coins
    Suports done. Need to connect and test. Waiting for milling parts.
    Update: Was tested with Arduino Uno connected to smc3 1.0 .
    I want use this sensor as analog :
    VCC - 5V
    OUT - PIN A0
    GND - GND
    I plug in and nothing happend... serching web... solved:
    You need to remove R4 (1k) resistor or connect GPO to VCC than You can read OUT pin as analog.
    source:
    https://forum.digikey.com/t/as5600-angle-magnetic-sensor-analog-out-problem/3325/4
      110.1 KB
      1,761
      113.4 KB
      355
      174.8 KB
      356
      172 KB
      445
  13. seuszok
    Poland
    477Coins
    Milling parts update
      169.6 KB
      399
      182.8 KB
      386
      164.3 KB
      387
      222.6 KB
      371
      214.7 KB
      387
      213.2 KB
      415
      237.3 KB
      1,624
      155.1 KB
      390
  14. seuszok
    Poland
    477Coins
    Another update
      169.9 KB
      677
      244.7 KB
      359
      237.5 KB
      1,642
      179.6 KB
      358
      186.9 KB
      363
      200.7 KB
      361
  15. seuszok
    Poland
    477Coins
    I assumed that the worm gear motor will not start without applying tension, but after mounting the arm, it can be turned using force.
    This causes joint collisions with the printed magnet element.
    New and improved elements have been printed, but it is not possible to adjust the angle of the magnet. You have to take out the magnet and insert it at the correct angle.
      164.4 KB
      325
      200.2 KB
      345
      133.2 KB
      428
      198.3 KB
      446
      170.5 KB
      329
  16. seuszok
    Poland
    477Coins
    After Sunday tests, 2 out of three IBT-2s were damaged (one direction), while 1 was spinning without any problems.
      224.8 KB
      402
      171.9 KB
      357
      39.3 KB
      387
  17. seuszok
    Poland
    477Coins
    I have question about hall sensor AS5600 like on my photos.
    The last days after work I sat in the garage at a temperature of -5deg and I can't cope with the hall sensors. At the beginning, I put everything together anyhow, and it worked. now I have uninterrupted peaks and jumps in the graph or he flow just sharpness up and down, I soldered all connections and it is the same. I checked on 2 others halls without changes. I connected through the new original arduino and no changes, I'm already a bit pissed because I put a lot of work into it and it doesn't still work. If you have any experience, please advise.
    I already have all the mechanical parts and should go on but no, what was supposed to be plug and play is trying to train me.
  18. Gadget999
    12,359Coins
    How does it perform when you take the weight off the motors
  19. seuszok
    Poland
    477Coins
    I won't tell you until I can deal with the disturbances that randomly rotate the actuators beyond the desired range (catastrophic collisions :)). Printing time after the collision is about 20 hours ... I do not risk it.
    -I tried to add a 1Mohm resistor but it didn't help
    -I do not like the usb cable yet but I do not have another (better)
    - I do not have ferrites yet (I read on the forum that they help)
    I am thinking more and more about ordinary rotary resistors, or as a colleague advised to put an as5600's on a separate arduino and read i2c.
    From the begining i use just axle of motor and hall sensor without an arm.
  20. Gadget999
    12,359Coins
    Turn the potentiometer by hand, do they read ok ?
