Showroom Motorcycle 4 DoF Motion sim
Discussion in 'DIY Motion Simulator Projects' started by Chris_Beeves, Sep 10, 2021.
  1. Gadget999
    12,156Coins
  2. superwhitewish
    superwhitewish Member
    Avionic Engineer
    Malaysia
    225Coins
    Hi, from the video that you posted, I see that the rig follows the motorcycle orientation in the game.
    But from my experience riding motorcycles, the rider is the one that push/pull the motorcycle to the left/right to counteract the centrifugal force when cornering. The bike lean to the left/right because the rider move it. If I ride at high speed and let say I want to take a left corner, what I need to do is to steer the handle to the left. At the same time I need to shift my body weight and lean the motorcycle to the left. If not the centrifugal force will slam the bike to the right.
    What I mean is that the feedback should be the centrifugal forces (sway in Simtools) that the rider can oppose by shifting his body. Maybe the rig and the actuator can be coupled thru a compression spring.
    Just my opinion.
  3. Chris_Beeves
    2,165Coins
    Thanks!
    I’m not going to sit on this scale model, so the motion is more for pleasing the eye rather than communicating g-forces. (The eye of the average Joe seems more pleased by seeing the bike lean the ‘right’ way)
    And you got it a little backwards with the steering I think. If you steer left, your bike will lean right. Try it in a safe place with lots of space some time. But that discussion is for another forum, not a build thread. :)
  4. superwhitewish
    Avionic Engineer
    Malaysia
    225Coins
    I'm not good in explaining things, even in my own language but that is what I mean actually :)
    Really hope you will built this project, it looks really good. Traction loss motion maybe a great addition. For when you do a power slide.
  5. Chris_Beeves
    2,165Coins
    Since there are two actuators at an angle in the back, it already has the ability to shake its’ behind. It acts as a kind of yaw, but with the center of rotation at the front fork pretty much.
  6. Chris_Beeves
    2,165Coins
    Ok, so I have a package waiting for me at the post office with 30kg of hardware and electronics from SimuKit!
    In two weeks the design phase will start and things will begin to really happen here!
  7. Chris_Beeves
    2,165Coins
    Monday we get to start! :D
    The SimuKit stuff have arrived, so now the electronics side should be pretty much set!
  8. itsumairu
    itsumairu Active Member
    Psychologist
    Indonesia
    440Coins
    Been following your thread, I think motorcycle sim is in another level.
    You really need a solid base and spacious room. And this is very hard for someone like me
    Can't wait to see how the final result works.
    Good luck with your project!
  9. Chris_Beeves
    2,165Coins
    Hello, and thanks!
    I’m not sure that needs to be true. We’re going to be focusing on motion cueing rather than motion replication, so it will be rather compact.
  10. itsumairu
    Psychologist
    Indonesia
    440Coins
    honestly I don't understand this motion cueing. gonna google it lol.
    but as a rider my self, I really can't wait to see how it works and the presentation of the final product.
    good luck!
  11. Chris_Beeves
    2,165Coins
    My friend and I started working more seriously on the rig this January. Updated first post with some progress.
  12. Chris_Beeves
    2,165Coins
    Updated first post again. Fabrication of parts started and alu parts are ordered :cheers
  13. Chris_Beeves
    2,165Coins
    The aluminum extrusion has landed and the steel parts are on their way to the powder coater. Now there is just some CNC work we're waiting for, after that we can start assembly!
  14. Chris_Beeves
    2,165Coins
    And also, the plugin work is really looking up!!
  15. Chris_Beeves
    2,165Coins
    Shaking its thing:
  16. Everson Neves
    Everson Neves New Member
    8Coins
    Muito agradável Chris.
  17. Arturo Cipriano
    Arturo Cipriano New Member
    Barcelona, Spain
    - 75Coins
    Chris, you are a crack. anything you need for the project you know you can count on me…..:thumbs:thumbs:thumbs
  18. Chris_Beeves
    2,165Coins
    Steel parts arrived yesterday!
    So far most of it seems to fit well.
    Now we need to mill a few parts we saved for ourselves, then we can get this thing moving!
  19. Chris_Beeves
    2,165Coins
    Testing out the lower platform lights:
  20. hideki
    hideki Active Member
    Spain
    - 208Coins
    2DOF, SCN5
    Nice!! Are you using SIMHUB for the lights? Thanks
