Tutorial DIY Bluetooth button for Steering wheel (only 10 USD)
Discussion in 'DIY peripherals' started by leductrinh, Aug 3, 2021.
  1. leductrinh
    leductrinh New Member
    31Coins
    result:
    Step by Step :
    1. accessory:
    - 01 Esp 32 board ( cost only 4 USD with clone board in VietNam)
    - 12 press button , 02 limit switch (for pad shifter)
    - Some aluminum sheet
    - 04 magnet (to keep the pad from wobbling)
    - 01 Mini power bank (01 cell batery 18650 ) output 5v ( cost 2 USD)
    2. conduct:
    draw:
    Cut and drill:
    grinding , weld , connect pad shifter:
    use magnet under pad (push each other)
    Wiring and code :
    it use matrix button 4x4 :
    Code and library attached (ESP 32.rar)
    Note: you need install 2 library for Arduino IDE before upload code to Esp 32. If upload error, you need put and hold BOOT button on ESP 32 while uploading
    • Winner Winner x 5
  2. hideki
    hideki Active Member
    Spain
    - 198Coins
    2DOF, SCN5
    excelent!! Its only 10€ in Amazon Spain.
  3. hideki
    Spain
    - 198Coins
    2DOF, SCN5
    leductrinh I see thats the same wheel base you use in your youtube video named "Dirt4 with motion", right? Are you planning to post how you did it? Or what characteristics it has? many thanks
  4. leductrinh
    31Coins
  5. hideki
    Spain
    - 198Coins
    2DOF, SCN5
