FlyPT Mover 3.5.3
  1. hexpod
    hexpod http://heXpod.xyz
    berlin
    7,770Coins
    DC motor, 6DOF
    I was struggling with the park pos. as well but it turned out that I was putting wrong range value for my 360deg. sensors and used scaling. (Should be 180 and scaling 1). After correction, park position sends the platform precisely to the assigned position in degrees.
  2. VirtualObsession
    IT developer
    Hertfordshire, UK
    280Coins
    I restarted Mover, the ESP32 and controllers and it didn't heave this time. I'm going to leave well alone until I get a better understanding.
    The first time I tried "set the current pose as park pose", I had heave at its lowest (all six Park at -59), but the next time I started up and connected, Mover kept heaving to highest position, doing the complete opposite. I set all Park to zero, but it seemed to be still heaving.
    I checked the Mover file PNLActuatorsOutput.nudDefault0-5, but they were zero or thereabout.
    It would be good if I can get the rig to lower itself at the end of each session. I'll have a look at what's going on via UDP to get a better understanding.
  3. VirtualObsession
    IT developer
    Hertfordshire, UK
    280Coins
    I finally have FS2020 where I want it at. Took hours of purposefully crashing planes into the ground, riding storms and doing loops and rolls. The immersion is insane.
    Started testing Dirt Rally 2. More of the same crash testing to see what's comfortable. I rolled a car down a hill and DR2 reset the car. At the reset, it felt as if the telemetry went from -20 degrees pitch to zero instantly. Is that telemetry coming straight from DR2? I'm not comfortable with that. It'll need lots of spike filtering. Mover can record telemetry, so I'll take a peek at what that was.
  4. pmvcda
    15,478Coins
    The car reset is near impossible to detect.
    If we got that info on the telemetry, I could add a transition on the filters.
    This happens in most games. Only way to handle it is the spike filter.
  5. VirtualObsession
    IT developer
    Hertfordshire, UK
    280Coins
    Thanks for confirming. :thumbs
  6. Acebk
    Acebk New Member
    - 31Coins
    How does a motion software like SRS implement rumble effect for racing sims, is it done through the telemetry? Can this be done using Mover? Thanks.
  7. Historiker
    9,208Coins
    It is part of mover now
  8. Acebk
    Acebk New Member
    - 31Coins
    I’m sorry if I wasn’t clear but I mean when the wheels go over a rumble strip on a race track that side of the rig rumbles. Can this be done like in SRS, I prefer Mover but it’s a nice effect.
  9. hexpod
    berlin
    7,770Coins
    DC motor, 6DOF
    I would say that your creativity is the limit ;-)
    The filtering possibilities and ability to superpose different modules with insane amount of filtering tools gives you a very large room do get whatever you can imagine
  10. hexpod
    berlin
    7,770Coins
    DC motor, 6DOF
    Instead of using the chaotic movement of the joypad I would set up slow loops to see exactly what’s going on there
  11. hexpod
    berlin
    7,770Coins
    DC motor, 6DOF
    Do I see correctly that the motion stops when the singularity filter goes red ?
  12. hannibal
    hannibal Active Member
    4,491Coins
    hey guys. im trying to get back into motion sim... does anyone have a link to simconnect that works with mover?
    or does the default simconnect dll is ok? unless the one included in mover is necessary?
    **update**
    running msfs2020 version 1.17.3.0 and the default simconnect dll works well with mover version 4.3.2
  13. hexpod
    berlin
    7,770Coins
    DC motor, 6DOF
    Once in developper mode you download the sdk and you have real-time access to all variables through a dedicated tool 377DD156-B60B-43E0-8530-8780322262AA.jpeg
  14. hannibal
    4,491Coins
    nice to know!
    do you mind sharing your msfs2020 mover profile? @hexpod ? maybe even DCS profile if you have one?
  15. hexpod
    berlin
    7,770Coins
    DC motor, 6DOF
    I posted a rudimentary one above in this thread. @pmvcda one could create a separate thread for user profiles or even better, you could develop a online access for user profiles directly in mover with user ratings
    • Agree Agree x 3
  16. greatg67
    greatg67 Member Gold Contributor
    509Coins
    I 2nd this request. An online repository of profiles would be an excellent idea...
  17. J-1775
    J-1775 Aviator
    1,582Coins
    This is great to hear! Is that for the BIGs or the small props (or both)? Would you mind giving us the settings of the POSES you use?
    For the past two weeks I've been working on a DCS profile (for their WWII props). Im quite satisfied with it, but since I use an unorthodox way of filtering pitch and roll (position with logistic) I couldn't implement ROLLOVER succesfully. So far ─ I won't give up!
    Your profile may not help me with that specific problem, but I'm eager to look into other solutions. And with Update 5 FS2020 is top on my list! ;)
  18. J-1775
    J-1775 Aviator
    1,582Coins
    I '3rd' this request, really a good idea! But a dedicated thread would already help a lot!
  19. J-1775
    J-1775 Aviator
    1,582Coins
    Kicking in: As I said in above post to VirtualObsession I don't feel ready to publish my DCS profile(s) as I consider them still BETA. But on second thought and if you explicitely ask, why not? Just «take it as it is» and be alert when rolling or looping over!:eek:
    I started with the P-51 profile which I then used for the Spitfire. Since I 'reengineered' some changes back into the P-51 profile, in the end they may not differ very much. I have GROUND RUMBLE ticked with the Spitfire, but unticked for the P-51. Do as you like. You may also adjust the TOUCHDOWN settings for Heave. With current settings you quickly learn how to make smooth 3-point landings...;)
  20. J-1775
    J-1775 Aviator
    1,582Coins
    @pmvcda: Another thought I had wrt enhancing user's benefit: a 'commentary' field attached to the settings where one can write down remarks like version no, changes and other specific notes that get quickly lost in memory.
