Showroom 2 DOF Seatmover (ZYT 90-155 / BTS-7960 / SMC3)
Discussion in 'DIY Motion Simulator Projects' started by RV10, Apr 14, 2017.
  1. RV10
    RV10 New Member
    GERMANY
    168Coins
    Hey guys, after months of reading in this superb forum I think it’s time to give you a short overview of my 2-DOF seatmover. Complete structure is made of black 40 x 40 mm aluminum profile. Parts are connected via steel brackets you should find in every hardware store – I painted them black to match the color of the aluminum parts and optimized them with rubber strips at the bottom to eliminate any kind of noise.
    Motors are ZYT 90-155 with 60:1 gearboxes that are powered by two HP DPS600PB server power supplies. I use one BTS-7960 per motor and arranged them in a DIY case made of plywood with a transparent top cover to see if everything is working fine. The whole system is cooled by four 100 x 100 mm fans that are powered by a single external 12V power supply.
    Seat and pedal mount are leftovers of my RSeat RS-1 I ran before. The pivot joint and lever arms are welded on 5 mm steel plates. CTC of the lever arms is adjustable from 50 – 80 mm. Shaft on rear side of the motor is glued – works flawless as there is no tension on the coupler and generally small torque needed to move the pots.
    Upcoming: Work my way into Simtools, cable management and some led lighting.
    If you have questions don’t hesitate to ask :);)
    :cheers
    • Like Like x 5
  2. Arta Yasa
    Arta Yasa Member
    824Coins
    How much price of motor and gearbox ratio sir???
  3. RV10
    RV10 New Member
    GERMANY
    168Coins
