3phase motors
Discussion in 'Marketspace - Marktplatz' started by Blekkulf, Jun 20, 2021.
  1. Blekkulf
    Blekkulf Member Gold Contributor
    Molde
    342Coins
    2DOF, AC motor, Arduino, Joyrider, 6DOF
    Just got my hans on at least 6 x 3phase motors with drives and worm gear. Planning on using some of them on my rig, but i will sell the others. Ive build three simulators now, and you cant get any better motors for a rig. I had a 80cm leaver on the output shaft, and it lifted 90kg without any problems. I think the input/output is 1500 / 132 rpm. Its so easy to power the drives with 110/230v from the outlet and just connect the reverse/fwd and speed signals from the arduino or whatever.
    https://www.ebay.co.uk/itm/124777183612 is the link to the motor with specs, the drive is matched with the motor.
  2. Gadget999
    12,035Coins
    They are nearly £9,000 each !
    You should be able to buy suitable motors that have a faster speed for less than 1k each
  3. Blekkulf
    Molde
    342Coins
    Why do you need more speed? Over 1m vertical movement in 1 sec :) yeah, way too expencive, but i got them all for free when we upgade some machines from those motors to pneumatics at my work.
  4. Gadget999
    12,035Coins
    For free, that will be a real find !
    I found that large actuation distances dont work well on a driving sim, more suited to flight sims
    Is this for a driving or a flight sim ?
  5. Blekkulf
    Molde
    342Coins
    Gonna be a sim for Dirt 2 this time :) 2 seater with co-pilot yeah.. was thinking about that.. not planning to use the full distance. A jump and a landing will probably be a lot of movement..
  6. SeatTime
    I'm running my 800mm actuators on 80% for heave in Assetto, with the Tuning Centre set to +- 20. The dynamic range this gives without any clipping is great. Feels much more realistic then I have had in the past on other sims with smaller actuators. As always, just my opinion.
  7. Gadget999
    12,035Coins
    does the +/- 20 mean 20mm or 20% ?
  8. Blekkulf
    Molde
    342Coins
    Nice! how long does it take to travel 80cm with the actuators ?
  9. SeatTime
    My actuators can move up to 500mm/sec.
  10. SeatTime
    It's my tuning centre setting for AC Ie. +/-20. For most sims with shorter actuators you would normally have to set this allot less for heave to get the required response.
