6DoF SFX100+100 TL Surge Sway
Discussion in 'DIY Motion Simulator Projects' started by Historiker, Mar 1, 2021.
  1. wannabeaflyer2
    london uk
    8,334Coins
    Hey Hey @Historiker ya struck gold there good buddy , that material is excelent for CNC Machining , Thats what i machined mine out of and loved it , Robust stuff , machinies well, and Hopefully ya got a bargin pricewise thats a lot of material :) i dream of getting that much of that material its expensive over here , Mine was 17mm thick and seriously well up to the task . so at 32mm Damm were in Abrahms Tanks levels of solidity .. Great find just for cureosity what did you search that under i.e phrase .. i might have to start looking at UK equivelent of craigs list if its gonna come up with these gems from time to time :)
  2. Historiker
    9,208Coins
    @wannabeaflyer2 I bought four sheets of 1-1/4" 24x50 and three sheets of 1/2" 23×58 for 250.00. That was a steal as a full 4x8 sheet of the former here is 1400.00 and a sheet of the latter is 200.00
    His asking price was 380.00
    My search was HDPE Sheet
  3. Historiker
    9,208Coins
    I have set up profiles for DCS, iRacing and Assetto Corsa. They work great. Driving games need serious filter tweaking for traction loss. For me, traction loss is NOT about trying replicate sway, I have a motor and linear rails taking care of that for me. I want actual traction loss, when the rear wheels come loose and the rear end kicks out. To get this I had to tweak the filters to ignore most inputs but react to fast large yaw accelerations. Hard to explain but one of these days I will post a screenshot of my filter setup. Probably the wrong way to do it but it is what I found to work for me.
  4. BondeX
    BondeX Active Member
    EE
    Michigan, USA
    1,501Coins
    When are the videos coming?
  5. Historiker
    9,208Coins
    When you come over and ride it. Need someone more friendly to the camera than I.
    • Funny Funny x 3
    151,668Coins
    +11,045 / 56 / -2
    Where possible I try and con family members for photo shoots ;)
  7. BondeX
    EE
    Michigan, USA
    1,501Coins
    Hopefully I will know by tomorrow if I can come over next weekend.
  8. RacingMat
    21,042Coins
    woah! incredible setup! with all these DOFs, it looks awesome
  9. Historiker
    9,208Coins
  10. RacingMat
    21,042Coins
    awesome like
    I want to sit on your simulator!!
  11. Historiker
    9,208Coins
    Not sure I am comfortable with that....lol
  12. Historiker
    9,208Coins
    My aluminum profile arrived yesterday, very fast shipping and a really good price. 250mm is 40.00 each but I went with 350mm for 60 each. Shipping was 24.00
    One little...tiny...problem with the profile though, and it will be a deal breaker for most, the four mounting holes are not holes....they are only 2/3 of a hole....but they are 10.5 mm so the right size for tapping.
    I knew this when I ordered them as I have a method of tapping the 2/3 hole anyway.i cut a 1/2" thick piece of aluminum plate to fit the bore. This allowed me to tap the holes.
    I am going to silver braze the m8 sleeves in just to be sure though.
    I could have had them tap the holes for me for a charge, and anyone that wants to use this brand probably should.
    I am going to create custom CAD files for the profile this weekend
    https://us.misumi-ec.com/vona2/detail/110302693970/
  13. Historiker
    9,208Coins
    HUGE thanks to @BondeX and his nephew for being my test du....er...drivers :)
    The squeaking that you hear is the four wooden blocks rolling around over the bolt heads! HAHHAA...yeah...a bit dangerous.....
    EDIT: The motor drivers are detuned for a max RPM of 1500 for testing.
    • Winner Winner x 7
  14. BondeX
    EE
    Michigan, USA
    1,501Coins
    Thanks for letting us try the simulator @Historiker, it was totally worth the trip and the motion felt absolutely amazing.
    • Friendly Friendly x 2
  15. Historiker
    9,208Coins
    A little progress today, still far away from finishing the SFX100+100 actuators....China far away :( My ballscrews, linear hollow slides and couplers have not yet shipped.
    I designed and cut top, bottom and slider parts. I only cut one set so I could test the fit. The only glaring issue is that I did not make the hole in the bottom one long enough to have the bearing fit toward the top, not the bottom. I redesigned it and will cut another one tomorrow. Overall the HDPE is an excellent medium to work with. Much better than that old batty fortune teller.
    I also tapped the M8/M12 sleeves into place. No need for the spacer, they drove in very nicely with a bolt/nut combination. I can highly recommend these profiles to everyone now.
  16. Historiker
    9,208Coins
    One nearly complete linear actuator. Wanted to assemble one to make sure the top and bottom are correct; they are :)
    I threaded 3/4 of the thread length in the HDPE and am letting the unthreaded section act as a lock.
    I did get notification that my parts have been shipped from China....now I am waiting for them to "actually" ship. They are coming UPS so once the company actually ships them I will have a good idea of when they will arrive. They said June 15th.....so...yeah.
  17. SeatTime
    That date may be purposely pessimistic, my last recent order from China (ballscrews) arrived weeks before their estimate. So you may be surprised like I was.
  18. Historiker
    9,208Coins
    I agree. I think that once UPS picks them up it will be no more than two weeks.
  19. Historiker
    9,208Coins
    UPS notified me that they picked up the package and it will be here on Monday!!!!
    yeah¡!!!!¡!!
  20. Historiker
    9,208Coins
    More parts arrived today, but there are issues.
    As you can see, the linear hollow rods are not square. Not as frustrating as it would otherwise be, I ordered them 400mm so I could cut them down to 370 for 350mm aluminum profile. I just had to cut and mill both ends
