Starting with the Video Plugin
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by ltijssen, Jan 20, 2010.
  1. ltijssen
    ltijssen New Member
    0Coins
    Hi all there, its my first time here. I'm working on a motion ride. I more or less copied the ideas of Mr. Burns and build a chair with 2 SCN6 150 mm actuators. My goal is to make a movie in lightwave (I was able to export the motion data from it) and play it with the video plugin. But as I am a beginner and most people make game simulators and don't use the video plugin I am a bit confused what configuration I need.
    I created a testmovie, exported the motion data and created a file I can import in the video plugin. So far so good. Now I started the force-profiler2 and checked in the input setup if any data was detected, but no there wasn't.
    I use the white version 2.0.8.8.
    I thought this should work. Does a noob tutorial about the video plugin exist?
    Regards, Lucas
  2. egoexpress
    egoexpress Active Member
    Germany - Frankfurt/M
    422Coins
    Did you select the video plugin in the Force Sender, and did you press try send data?
    regards
  3. ltijssen
    ltijssen New Member
    0Coins
    It works, thanks. I actually didn't think the force sender was needed for the video plugin. :blush:
