FlyPT Mover 3.5.3
  1. digitalmonk
    digitalmonk Member Gold Contributor
    Canada
    239Coins
    It's actually Dirt Rally 2. I followed your youtube setup for DR2, but I think the sfx100 behaves WAY differently compared to the Hexapod in the video. The motion is not the same, but I tried adapting some of the filters. I'll try MALP and see if that changes things.
    So something like this for Surge?
    MALP(EMALP(VALUE;150);50) what does the last value mean? Number of Samples?
  2. pmvcda
    15,666Coins
    That's two smooth filters.
    Try using just one MALP
    Two EMALP round it a bit.
    So if you want to use two, do EMALP(MALP(VALUE;200);200)
    The numbers is the samples for each filter
  3. Anjan Deb
    Anjan Deb New Member
    41Coins
    Thanks a lot for the quick and helpful response. I at least started to see things moving in front of me. Can you please recommend some reading material for me to understand what Just Pose is doing and how can I tweak it to tune the pose. Its all over the place at the moment.
    Thanks again
  4. pmvcda
    15,666Coins
    Www.flyptmover.com
    Trying to compile everything on the same place.
    Next version has help links to those pages.
  5. Anjan Deb
    41Coins
    Cool. Thanks.
    Is there a way to achieve unlimited YAW, since YawVR supports it?
  6. pmvcda
    15,666Coins
    Yes, it already works.
    The rotation is handled by the hardware.
    Mover sends between - 180 and 180 degrees.
    YawVR rotates to the closest angle.
    So if it wants to go from 170 to - 175, the fastest and shortest travel is to make 15 degrees going over the 180 compared to making 345 the other way around....
    Well hope I explained how it works.
    • Informative Informative x 3
  7. Anjan Deb
    41Coins
    cool. Thanks a ton. Really helpful.
  8. digitalmonk
    Canada
    239Coins
    Awesome thank you! Will try this.
  9. Anjan Deb
    41Coins
    Hia.. i need some help from you. As you suggested, i went through flyptmover.com and using the material available have setup a DR2 profile for YawVR. Used the justpose rig as you suggested. Its all ready to test with actual yawvr. I hv tested it with yawvr emulator running on same machine. Its all good. However i dont know how shall i connect it with actual yawvr rig.
    I could not find reading material on the flyptmover.com. can you suggest where can i find the info?
  10. pmvcda
    15,666Coins
    Yes, still need to add the outputs to the manual.
    But To connect with Mover you use the same settings you use with SimTools.
    I might add a dedicated output using the yawvr sdk when I get some time.
    Do the following:
    Add a just pose rig. This generates just the rotations, so I changed the limits of the pose to 0 in the linear dof's, and 25º for pitch/roll, 180º for yaw.
    Don't forget to put position bit to 12!
    Add a serial output with the following settings (got from the YawVR manual here):
    Attention to the decimal and the 6 to make updates @12ms.
    And change the IP to the IP of the YawVR.
    I'm still working on it, so the keys I show, might change name in the future.
    Should now work. Use a pose, that you need to choose in the rig (right column).
    Waiting for some feedback ;)
    EDIT!!!!
    This is wrong, the serial string should be: YS[<Yaw>]P[<Pitch>]R[<Roll>]B[12]
  11. Anjan Deb
    41Coins
    Just checked it. Let me try. Thanks a ton.
  12. Trip Rodriguez
    Trip Rodriguez VR Pilot
    Lake Ariel, Pennsylvania
    3,977Coins
    @pmvcda as always, thanks for all your hard work!
    I'm back, and trying to help J get his sim working with Mover.
    I'm in WAY over my head here, but if I understood correctly your last reply to me, it appears that J needs "position" output in 2 bytes.
    Two sets of 3 digits in the output is 2 bytes, is that right?
    So what output string do we now use to output "Position" in 2 bytes? In "Rig", we have it set to 16 bit. If possible, just give me an example of EXACTLY what to put between the < and > . Am I understanding correctly that it is just <BSway> <BSurge> etc. now, with 16 Bit selected in "RIG" for position output in 16 bit?
    Extra info: What his simulator is expecting is described this way by the manual for his sim:
    platform offset: Data SIZE is 16 bits
    • Axis 1 represents platform surge (+/-)
    • Axis 2 represents platform sway (+/-)
    • Axis 3 represents platform heave (+/-)
    • Axis 4 represents platform roll (+/-)
    • Axis 5 represents platform pitch (+/-)
    • Axis 6 represents platform yaw (+/-)
    Apologies if I'm not on the right track, I have no prior understanding of these things outside of what little I've learned here and my memory is not very good.
  13. pmvcda
    15,666Coins
    Remind me of what type of rig and controller he's using.
    Sorry, so many questions between hera and discord channels, that I loose track.
    • Friendly Friendly x 2
  14. Mauricio
    Mauricio Member Gold Contributor
    75Coins
    Hello friends, I followed the instructions in the Manual, however the F12020 is not sending data or the platform is not receiving it. Did anyone go through something like that?
  15. pmvcda
    15,666Coins
  16. Trip Rodriguez
    3,977Coins
    I understand! I do not know how you keep up as well as you do!
    I am pretty sure all I need is an up to date explanation of the prefixes for the "keys" for the output string.
    Just trying to save you time, so the below (grey) text is an answer to your question you may skip reading if you wish!
    J is trying to get FlyPTMover to work with his EDGE6D motion platform from gforcefactory.com, and the manufacturer is actively trying to help get their simulator working with FlyPT Mover.
    His sim is a hexpod with unusual geometry, and the controller wants DOF offsets, rather than actuator offsets.
    We think we are almost there, but not sure what option to use in the output string to get the outputs to be DOF position offsets in 2 bytes each (16 bit IS set in RIG).
  17. Mauricio
    75Coins
  18. mm982566
    mm982566 New Member
    US
    56Coins
    3DOF, 4DOF, 6DOF
    Hello, I see that you are using SIMHUB at the same time, UDP port cannot send data to two programs at the same time, so you can try to change the receive port of FLY to 20778, the forward port to 20777, and tick the box in front to change the port in F12020 to 20778, and the port in SIMHUB to 20777. Good luck to you.
  19. Mauricio
    75Coins
    Thank you so much. Im gonna try to do it!
  20. Mauricio
    75Coins
    Agora tenho outro problema. Baixei a última versão do FlyMover. Há uma nova fonte para MSFS2020, mas não aceita adicionar. Por quê?
