Building a new 6DIY
Discussion in 'DIY Motion Simulator Projects' started by Flymen, Aug 22, 2018.
  1. Thanos
    Electronics Engineer
    2,692Coins
    Email me, we will short it out.
    Can I ask, what servomotors do you have? What is the servo drive part number?
    Thanos
  2. Thanos
    2,692Coins
    The AMC-AASD15A use pulse/Dir control method and is not reading back the servomotor encoder position as its not necessary. Its actually more advanced while having simpler connections and can calibrate the servomotor home position using torque signal feedback from the servo drive.
    But yes, the issue is you DONT HAVE SERVO DRIVE... All you have is a BLDC brushless speed controller. You could try your luck with Odrive perhaps although it will be more expensive solution, three Odrive would cost you about 360USD...
    But maybe you could interface to FlyPT esp32 system, see here:
    https://www.xsimulator.net/communit...hless-diy-actuators.10799/page-25#post-191594
    Thanos
  3. Flymen
    Montreal, Canada
    2,415Coins
    DC motor, 6DOF
  4. Flymen
    Montreal, Canada
    2,415Coins
    DC motor, 6DOF
  5. pmvcda
    14,096Coins
    Similar to what I made, the idea is to work like a spring, and round to easily rotate to both sides.
    Mine is petg, with 2.5mm from what I remember.
  6. Flymen
    Montreal, Canada
    2,415Coins
    DC motor, 6DOF
    Ok , thanks
    I did a wall of 2.0 mm finaly , it seem like good and flex !
    Used : ABS M30 ( where I work ) ;)
  7. misoswan
    misoswan Active Member
    1,000Coins
    3DOF, Arduino, JRK
    I want to ask what it is and how it is used? I found to same it in the drawings @Silent Chill .thanks
  8. Flymen
    Montreal, Canada
    2,415Coins
    DC motor, 6DOF
    This wheel is a guide fix at the top of the ballscrew, it prevents the rod from vibrating( anti wobble ring) in the tube when the bearing travels in the low position and when the coupling is misaligned !
  9. Flymen
    Montreal, Canada
    2,415Coins
    DC motor, 6DOF
  10. SilentChill
    20,396Coins
  11. Flymen
    Montreal, Canada
    2,415Coins
    DC motor, 6DOF
    With the covid-19 ,
    he must have passed before his scheduled time , but Maman Noel , should pass by the end of November if all goes well (G2) ...:think
  12. Pierre Lalancette
    3D teacher
    Quebec, Canada
    7,683Coins
    3DOF, DC motor, Arduino, 6DOF
    Some people have way too much money to spare.
    Have fun!
  13. Flymen
    Montreal, Canada
    2,415Coins
    DC motor, 6DOF
    G27 STEERING IS DOWN ( BROKEN) . DON’T GRIP TOO MUTCH YOUR STEERING WHEN YOUR RIG MOVE TOO HARD :grin I WILL BUY A RED SAFETY SEAT BELT !
  14. Pierre Lalancette
    3D teacher
    Quebec, Canada
    7,683Coins
    It's never fun to have brand new tows breaking at first tries.
  15. Flymen
    Montreal, Canada
    2,415Coins
    DC motor, 6DOF
    FB930E9A-C05C-4617-ACA5-9B1793B406C9.jpeg New blue box for my arduino uno !!! G27 pedal don’t fit with the New steering !!! I must pass Db9 to USB
  16. Flymen
    Montreal, Canada
    2,415Coins
    DC motor, 6DOF
    New ajustement ,COG is 4 inch back Now because this motor is heavy 30 lbs , Clean up of wire and cable !
    Baby is ready again ! Miss only pedals who missing code for arduino uno !!
    5F340324-0CA7-4009-8262-99A7C2A505AF.jpeg 15D7E93A-671E-4E5A-A834-2810BAE6FF05.jpeg F61A03E8-9D9A-4A99-8C1D-18C8FDCBEB9F.jpeg 1A5CA784-C34A-4024-BB45-2CCC688BC8C6.jpeg
  17. absyfadhel1
    absyfadhel1 Member
    bahrain
    422Coins
    is that fan for wind simulator ..if its that so your build fantastic!!!
  18. Flymen
    Montreal, Canada
    2,415Coins
    DC motor, 6DOF
    Yes , is those two fans who blow on me !:grin
  19. Flymen
    Montreal, Canada
    2,415Coins
    DC motor, 6DOF
    • Funny Funny x 3
  20. Pierre Lalancette
    3D teacher
    Quebec, Canada
    7,683Coins
    The only problem I see with that is that there's place for only ONE beer.
