2dof (plywood and aluminum profile construction)
Discussion in 'DIY Motion Simulator Projects' started by Michael_miass, Oct 24, 2020.
  1. Michael_miass
    Michael_miass West
    Russia, Miass
    725Coins
    Good afternoon! I am writing via google translate. I want to do 6DoF construction, but for now I decided to start small and do 2dof construction. And so less words, more pictures !!!
    1. Drew the model. No engines yet;)
    1. Sawed plywood and wooden blocks
    3. Cutting aluminum profile
    4. Bought a thrustmaster T150 steering wheel
    8. I am 3D printing various parts IMG_20200930_225954.jpg IMG_20201024_221338.jpg
    Tomorrow I'll go buy bolts and nuts :)
    To be continued: show your teeth
    153,914Coins
    +11,156 / 57 / -2
    Nice progress, thanks for sharing your build :thumbs
    What motors and control boards do you plan to use?
  3. Michael_miass
    Michael_miass West
    Russia, Miass
    725Coins
    I want to use 188W BLDC motors and RV030 worm gearboxes
  4. Michael_miass
    Michael_miass West
    Russia, Miass
    725Coins
    Bought bolts and nuts
    Pre-assembled the structure. With active steering, the rigidity of the structure is not enough IMG_20201025_210530.jpg
    Drew a new reinforced model
  5. Michael_miass
    Michael_miass West
    Russia, Miass
    725Coins
    I tried on the hinge on the base
    Assembled a reinforced structure. The construction is rigid and reliable. I'm happy as an elephant :grin. Tomorrow I will assemble a block with pedals and look for the center of gravity.
  6. Michael_miass
    Michael_miass West
    Russia, Miass
    725Coins
    Found the center of gravity using a pipe and installed a hinge there
    Installed pedals
    Printed on a printer a cap for an aluminum profile
    Installed traction
    Here are some more photos
  7. SeatTime
    What gearbox ratio are you going to use to drive this? The drive point you have chosen will require quite a bit of torque.
  8. Michael_miass
    Michael_miass West
    Russia, Miass
    725Coins
    I want to use a 40: 1 gearbox
  9. Michael_miass
    Michael_miass West
    Russia, Miass
    725Coins
    Photo of the gearbox RV030 ratio 40 from aliexpress
    Have a question. Should the red plug be screwed in instead of the screw on top? There is a hole in the plug. What is this for? for the reducer to breathe
  10. Michael_miass
    Michael_miass West
    Russia, Miass
    725Coins
    I counted the efforts on the rods. With a torque on the gearbox of 20N * m, the maximum force on the crank is 60 centimeters - 333 N. At the bottom point when moving upwards - 214 N. At the top point, the worst situation is the effort just taking into account two angles 70.4N
  11. Michael_miass
    Michael_miass West
    Russia, Miass
    725Coins
    Unsealed and installed the crank
  12. Michael_miass
    Michael_miass West
    Russia, Miass
    725Coins
    Printed with ABS plastic, 60% filling. I think this will be enough
  13. Michael_miass
    Michael_miass West
    Russia, Miass
    725Coins
    Potentiometer coupling. The legs of the green part break faster than the potentiometer. Everything is attached to the gearbox.
    • Creative Creative x 2
  14. tomkil192
    tomkil192 Member
    Uk. London
    - 24Coins
    good progress. well done!
  15. Michael_miass
    Michael_miass West
    Russia, Miass
    725Coins
  16. Michael_miass
    Michael_miass West
    Russia, Miass
    725Coins
    While I'm waiting for the drivers motor, I printed more rings for screws
    It was
    became
  17. Banfy
    Banfy FR/AU
    Australia
    299Coins
    DC motor, Arduino
    Very nice design!
  18. Michael_miass
    Michael_miass West
    Russia, Miass
    725Coins
    additional hood design:grin
  19. ChubbyWeasel
    ChubbyWeasel New Member
    USA
    65Coins
    It's small details that add to your design. Very nice.
  20. Michael_miass
    Michael_miass West
    Russia, Miass
    725Coins
    Tested cheap drivers for 7 euros. They work very badly:mad:. Change directions for a long time (approximately 0.5-1 seconds). As a result, I burned it and I do not regret it much:)
