Ccruz build
Discussion in 'DIY Motion Simulator Projects' started by Ccruz, Sep 15, 2020.
  1. Ccruz
    Ccruz New Member
    131Coins
    Thanks soo much!
    787-244-7433 if you have whatsapp
  2. Ccruz
    Ccruz New Member
    131Coins
    It's connected, when on, it keeps moving. When touch both ext ( limit switch) it stop. When touch the bottoms it move but fast to one side and slowly to the other. In 100 stroke just move a little. I put it in 430 stroke to make one complete turn. Stock parameters
  3. Ccruz
    Ccruz New Member
    131Coins
    Baj send me this and he tell me that showing this to you you can send me best adjusting
  4. Ccruz
    Ccruz New Member
    131Coins
    I think that Just need to set parameters.
  5. Thanos
    Electronics Engineer
    2,908Coins
    Sorry for the delay, I'll definitely look at the parameters as soon is possible.
    One thing if you want to quickly try is to find the parameters for electronic gear and set the nominator to 20 and denominator to 1... this will give you 20:1 ratio on the pulses to match the pulse ratio of the AASD-15A servos.
  6. Ccruz
    Ccruz New Member
    131Coins
    I think you are referring to this?
  7. Ccruz
    Ccruz New Member
    131Coins
    Making the end joint cap.
  8. Ccruz
    Ccruz New Member
    131Coins
    I'm getting 22 turns on the servo motor shaft going from home to 50% Park in 430mm stroke.
  9. Thanos
    2,908Coins
    Try this:
    Thanos
  10. Ccruz
    Ccruz New Member
    131Coins
    Thanks soo much. Will try this today when arriving home. :)
  11. Ccruz
    Ccruz New Member
    131Coins
    I need to connect the blue cables or can just connect direct to the ext on the board
  12. Thanos
    2,908Coins
    Since you are making custom wiring, you might as well wire the limit switch on the cable... it will simplify things if you want to swap the motor order around later etc.
  13. Ccruz
    Ccruz New Member
    131Coins
    Sensors arrive
  14. Thanos
    2,908Coins
    Cool!! You should be able to wire them as on the following video:
  15. Ccruz
    Ccruz New Member
    131Coins
    Perfect, I will take a video today and upload it to YouTube to send you the link here.
  16. Ccruz
    Ccruz New Member
    131Coins
    Home calibration
  17. Thanos
    2,908Coins
    Good, but make sure to set park position to 0 (zero)... seems you have it set to 50%
  18. Ccruz
    Ccruz New Member
    131Coins
    I will be putting the sensor horizontal in the actuator pipe. Here the magnet holder.
  19. Ccruz
    Ccruz New Member
    131Coins
    Hi, I'm installing the system, only problem I have is in one of the actuators. When I begin playing, one of them stop working. No error in driver, just servo lost power because I can move it with my hands. I need to turn off the system and turn on again but same happens few seconds after begin playing. I see that the fan of the driver turn off also.
  20. Thanos
    2,908Coins
    Do you see any alarm message on the AASD-15A servo drive panel?
    Check your wiring, maybe something is loose on the db25 plugs...
