Tutorial DIY 3D printed Sim Racing Hydraulic pedals SRT
Discussion in 'DIY peripherals' started by Lebois, Jan 26, 2020.
  1. Lebois
    Math teacher
    2,566Coins
    Anything that looks like the ender 3 will be good enough :)
  2. Squarebob
    Squarebob Member Gold Contributor
    Georgia USA
    70Coins
    DC motor, Arduino, 4DOF
    So I went into turn 4 a little too hot!!!!!!
  3. 7HUND3R
    7HUND3R Active Member
    1,159Coins
    Do you have it fixed the 2 pedals with 1 single bar? Wouldn't it be better to put 2 fasteners like the ones you have at each end of each pedal?
      118.3 KB
      434
  4. Squarebob
    Georgia USA
    70Coins
    Shaft doesn't flex a bit. Have spacers on the shaft to keep the pedals properly seperated. Should have used a different infill and pattern when printing the pedal. Oh well. Made a new one out of metal and also fabricated a handbrake for racing in DiRT 2.0
  5. 7HUND3R
    1,159Coins
    Oh my god, I see a lot being done there !!!! I am making mine, soon I will upload photos of my pedals.
  6. Lebois
    Math teacher
    2,566Coins
    Can you share the the infill % you used ?(and even add it under the picture) I never managed to break mine.. ^^
  7. 7HUND3R
    1,159Coins
    Photos of how it looks
  8. Squarebob
    Georgia USA
    70Coins
    I don't have the file any more but I am thinking about 75%. Here is a slice from the gcode.
  9. Lebois
    Math teacher
    2,566Coins
    @Squarebob hm... I will try to brake my 80% infill brake lever when I will have more time.
    Which 3D printer do you use ?
  10. RacingMat
    21,068Coins
    infill is probably not the answer to strength...
  11. 7HUND3R
    1,159Coins
    I can't help much since I've never had a 3d printer and don't know its settings. But I just ordered an ender 3. The thing about the broken pedal I want to think that it is rather because of the single axis that fixes all the pedals.
    • Optimistic Optimistic x 1
  12. Lebois
    Math teacher
    2,566Coins
    @RacingMat infill is the simplest answer, not the most efficient :)
    Infill patern or a print issue can be the cause of the breakage... By the way, the 5.3 lever is stronger around this area.
  13. 7HUND3R
    1,159Coins
    Nuevo progress
  14. Lebois
    Math teacher
    2,566Coins
    Very nice looking !
  15. Raumo
    Raumo New Member
    56Coins
    I could not find any steel axles so I made my own by using the beta plastic axle but modified it with a hole so i could insert a M6 threaded rod through it, feels pretty solid to me (but haven't tried it yet). So just a tip if anyone has the same problem.
    • Old Old x 1
  16. 7HUND3R
    1,159Coins
    I have printed a part in 3d on my ender 3 but it doesn't come out right. why?
  17. Raumo
    Raumo New Member
    56Coins
  18. 7HUND3R
    1,159Coins
  19. Raumo
    Raumo New Member
    56Coins
    200 should be ok, 60 might be too much. Lower to bed to 55 or 50, if that does not work lower nozzle by 5.
  20. 7HUND3R
    1,159Coins
    I have lowered the tray by 20 degrees and the tip by 5 degrees and now it has come out better.
