Motion Simulation Software SimTools SimTools v2.6.1
SimTools Release Version
  1. yobuddy
    47,910Coins
    Yes, simply install over the top of 2.4 to update!
    Take care,
  2. Arielnac
    Arielnac Member
    Argentina
    65Coins
    Hi. Install the new version 2.4.1 but I have problems. The movements are erratic. The output testing does not work as it should. I went back to version 2.4 and everything normal
  3. Michael Jeffries
    Michael Jeffries Member Gold Contributor
    485Coins
    Motion platform, 4DOF
  4. yobuddy
    47,910Coins
    The washout filter worked fine, but the traction loss one would not activate.
    (does now thou!)
  5. Michael Jeffries
    485Coins
    'Sorry, Im confused. I dont know which washout filter. I am using Extra1 for TL on iracing's plugin and it works fine in the last update and this one. What changed?
  6. yobuddy
    47,910Coins
    The traction loss filter now washes out as needed. (washout speed depends on your min/max numbers.)
  7. Michael Jeffries
    485Coins
    I just saw that Washout filter below Traction loss - didnt pay attention to them before. I'd have to play with them to see what they do. I think i left it at 0 for Traction loss.
  8. yobuddy
    47,910Coins
    The Gain above is only for washout.
    With the traction loss filter, you just adjust the min/max numbers as needed.
    (Centering to fast, use bigger numbers, centering to slow, use smaller numbers.)
    Take care,
  9. Mu-KwangKim
    South, Korea
    - 689Coins
    @yobuddy Hi. I'm always using it well. Thank you.
    But, When are you going to solve the problem of changing the local language setting?
    If I change the local language setting, simtools works well, but it is a little difficult because other programs often break letters... Some of the menus in Axis are also hidden, so it is not possible to set filters for DOF6.
    I hope you can resolve it if possible.
  10. Keith
    Keith Active Member
    Electrician
    Canada, Saskatchewan
    118Coins
    2.4.1 did not work with my system. Movement was not right. I tried adjusting things but ended up going back to 2.4
  11. yobuddy
    47,910Coins
    V3 has been re-written from the ground up and should kick this problem once and for all. :thumbs
  12. yobuddy
    47,910Coins
    2.4.1 is just 2.4 with a couple of bug fixes.
    If you weren't using 14bit output or the traction loss filter then nothing has changed really.
    I would guess its anti-viruses learning (thumb printing of sorts) 2.4.1.
    Either way thou, v3 will be properly signed to avoid antivirus problems in the future.
    Thanks for the report!
    Take care,
  13. Keith
    Keith Active Member
    Electrician
    118Coins
    Cool. I look forward to v3. Keep up the good work
  14. tracer99
    tracer99 New Member
    - 72Coins
    Is there still an link to the old Version 2.4.0?
    I got some big trouble after updating from 2.4 -> 2.4.1.
    Just have 2.3 in HD stored. With 2.3 everything works as before. Therefore I would like go back to 2.4.0.
  15. Keith
    Keith Active Member
    Electrician
    118Coins
  16. Scblacksunshine
    Scblacksunshine Member
    270Coins
    2DOF, 3DOF
    Please look into the issue of Serial Interface not working. I think it has something to do with the Serialinterface.dll file. I used the one from 2.3 and It's working.
  17. SeatTime
    28,370Coins
    Agree, something not right with the serial interfaces - some work, some don't, some don't work right. Rolled back to 2.4 - everything is fine.
  18. tracer99
    tracer99 New Member
    - 72Coins
    144,614Coins
    +10,741 / 52 / -2
    Are you logged in, as the Download link should then be in the right column.
  20. Arielnac
    Arielnac Member
    Argentina
    65Coins
    Yes. I have the same problem
