Thanos Direct Drive
Discussion in 'Direct Drive Wheels' started by Gadget999, Jun 5, 2020.
  1. Gadget999
    12,072Coins
    Finally the board has arrived after getting stuck at the airport for nearly a month !
    Pic attached, you can see it is neat and smaller than the disco board.
    I will map the pinout to fit the mige servo driver and take it from there
    Cant wait to get it working
  2. Gadget999
    12,072Coins
    @Thanos
    can you confirm that these pins are the same as the D25 connector that is the output on your board
    are all pins used ?
    1 GND
    2 PV pulse input
    3 PP+ port
    4 PD+
    5 PD-
    6 sig in 1
    7 sig in 2
    8 sig in 4
    9 DC 12-24v
    10 COM / GND
    11 sig out 1
    12 sig out 3
    13 AGND Analogue Gnd
    14 PP-
    15 PZ+
    16 PZ-
    17 PB-
    18 PB+ encoder output
    19 PA- encoder output
    20 PA+ encoder output
    21 sig in 3
    22 OZ
    23 sig out 2
    24 sig out 4
    25 Vref +/-10V'
  3. Thanos
    Electronics Engineer
    2,901Coins
    No, you only need these:
    Thanos
  4. Gadget999
    12,072Coins
    what is the EN pin ?
    is it gnd for the direction pin ?
    Edit - the EN pin is to enable the motion
    @Thanos
    How does the torque signal/voltage work
    Is it 0-5 v ?
  5. Thanos
    2,901Coins
    The Torque signal is 0-3.3v analog voltage from the DAC. Its using the DIR pin to determine the direction of the Torque.
  6. Gadget999
    12,072Coins
  7. Gadget999
    12,072Coins
    i have the TDD board installed and powered up the direction LEDS are worlking as i turn the wheel and the torque pin25 is outputting a voltage
    should I have the servo driver in position mode or torque mode ?
  8. OZHEAT
    OZHEAT Active Member
    Australia
    2,459Coins
    3DOF, DC motor
    torque mode
  9. OZHEAT
    Australia
    2,459Coins
    3DOF, DC motor
    @Gadget999
    I will try to help you setup your drive, it will be different to the AASD.
    I am looking at the parameter setup to reconfig your Di for direction.
  10. Gadget999
    12,072Coins
    thank you @OZHEAT - it is very much appreciated
  11. OZHEAT
    Australia
    2,459Coins
    3DOF, DC motor
    NOTE EN should be pin 12 and DIR should connect to pin 11 on CN1 servo drive
  12. OZHEAT
    Australia
    2,459Coins
    3DOF, DC motor
    connect as pic and will see if you can at least enable servo first.
    need to know whether you need can use 5v to enable inputs
    might be easier if you do away with the TDD board and connect directly to the STM32 board
  13. OZHEAT
    Australia
    2,459Coins
    3DOF, DC motor
    parameter P3-1 (Digital Input D12 Function) set to 9 (CINV) Instruction reverse.
  14. OZHEAT
    Australia
    2,459Coins
    3DOF, DC motor
    Can you measure with multimeter if PIN 10 on servo drive CN1 has 24VDC on it or is it open?
  15. Gadget999
    12,072Coins
    ok i have wired as you suggested and set --
    the voltage from pin 10 is 1.67 volts
  16. OZHEAT
    Australia
    2,459Coins
    3DOF, DC motor
    @Gadget999
    Ok connect +5v from TDD to P10 on your servo drive CN1
    You should be able to drive your servo now.
    Do you need help with the other parameters such as speed limit, torque max power etc as well?
  17. Thanos
    2,901Coins
    here are the parameters I used for TDD with the DAC function:
    PN002 = 0 (control mode - voltage mode, requires restart)
    PN003 = 0 ( Servo enabled? - external)
    PN018 = 0 (Take the encoder output pulse AB phase logic - 0-1)
    PN051 = 1500 (Motor max RPM - see motor specs)
    PN053 = 18 (SigIn 2 port functional allocation -27 - 27)
    PN188 = 10 (Analog torque instruction smooth filtering time - 1-500ms)
    PN189 = 100 (Analog torque instruction gain 1-300 %/V)
    PN190 = -100 (Analog torque instruction offset adjustment -1.5v - 1.5v)
    PN191 = 0 (Simulation of torque command direction - try 0 first)
    PN198 = 500 (Torque control speed limit - 0-4500rpm)
    Thanos
  18. Thanos
    2,901Coins
    just noticed, you are using Mige servo drive... not sure for the parameters on that.
  19. OZHEAT
    Australia
    2,459Coins
    3DOF, DC motor
    @Gadget999
    Sorry I told you the wrong parameter to set
    parameter P3-2 (Digital Input DI3 Function) set to 9 (CINV) Instruction reverse.
    Set back parameter P3-1 (Digital Input DI2 Function) set to 2 (ARST) alarm reset (default)
    Lol I also gave you the wrong pins:rolleyes:
    connect EN to 12 on CN1(servo enable DI1)
    and DIR to 11 on CN1(CINV DI3)
    DI2 can stay to as Alarm reset if you want to connect button
  20. Gadget999
    12,072Coins
    ok that seemd to help
    the servo is now braking - crikey its got some power !
    turning the wheel clockwise there is a lot of resistance
    anti clockwise there is almost no resistance
    also the usb device seems to fail
    i will try wiring the pin 10 to a 12v power supply and report back
