Riton' 2DOF with AC gearhead motors
Discussion in 'DIY Motion Simulator Projects' started by riton, Jun 8, 2009.
  1. riton
    riton Active Member
    1,006Coins
    Re: Riton' 2DOF project with AC gearhead motors
    I have a problem, and I do not know how to fix this problem:
    sometimes when I play for some time, the simulator goes alone stop, the simulator stop, I must press start again, why?
  2. riton
    riton Active Member
    1,006Coins
    why software disconnect and stop the simulator ??
    no ideas?
    thanks
  3. egoexpress
    egoexpress Active Member
    Germany - Frankfurt/M
    421Coins
    I think there has been an issue with the pnp option. Try to disable it, and see if it works better.
  4. riton
    riton Active Member
    1,006Coins
    thank you very much, I will try tomorrow ....
  5. riton
    riton Active Member
    1,006Coins
    I tried with PNP on (default) then I have removed (off)
    I have the same problem, the Profiler goes off, I must once again press start.
    I use the latest version
  6. riton
    riton Active Member
    1,006Coins
    lot of video on youtube:
    http://www.youtube.com/watch?v=dV09pQvCG0s
    http://www.youtube.com/watch?v=CZEipkP7M1I
  7. riton
    riton Active Member
    1,006Coins
  8. riton
    riton Active Member
    1,006Coins
    my simulator is really well,but I have always the problems with x sim, it's disconnect .
    X sim stop, stop button and stop the simulator, why? Did you have a idea ?
    it happens often if I remain without moving, or if I made the move draft
    if I drive fast, no problem, against if I drive slowly, sometimes it disconnect and stop the simulator
  9. riton
    riton Active Member
    1,006Coins
    new video, test with my projector
    http://www.youtube.com/watch?v=_uaowgKcHEg
    http://www.youtube.com/watch?v=nGi1fEBtLJg
  10. riton
    riton Active Member
    1,006Coins
    le simulateur cherche sa position centrale et est sencé s'arrêter, j'ai réglé la matrice dans outpout pour ça, arrêter tout en off les moteur off, et la vitesse off.
    le problème c'est que le centre c'est 50% de laxe, 49% c'est pas bon et 51% non plus , alors faut être vachement fort comme simu pour s'arrèter pile au centre!!
    du coup le simu fait le yoyo et s'arrète jamais au centre!
    alors on a un réglage de sensibilité du pad ou de la mesure de position de l'axe, c'est bien mais ça fait pas grand chose a part diminuer la précision, ça régle pas le probléme.
    la réactivité de l'axe non plus ça met juste du retart a l'effet, ou plutot du retard au changement d'état, le temps de réaction entre 2 infos de mouvement.
    est il possible d'avoir une zone neutre réglable entre 47 et 53, c'est le centre, comme ça il serait à 0 et pourrait s'arrêter sans faire le yoyo!!
    sans ce truc la je voie pas comment éviter ce yoyo, la marge de manoeuvre est trop courte!faudrait trouver un accéléromètre avec un réglage de ce genre a la limite pour compenser ce manque
    vos avis?
  11. riton
    riton Active Member
    1,006Coins
    sorry for this french message, but , its difficult for me to make a good explication in english :sos:
    when my simulator is at the center, my axis are 50%
    but when I press start, the simulator can not stop in the middle!
    it moves constantly! around the center
    it's too hard to stop at 50% clear, impeccable, it's impossible!
    I need to set a dead zone between 47% and 53%
    is that possible, or how to stop the simulator at the center without moving?
    thank you
  12. riton
    riton Active Member
    1,006Coins
    i test a new profile...
    http://www.youtube.com/watch?v=2F8vcPu5mgQ
  13. riton
    riton Active Member
    1,006Coins
    http://www.youtube.com/watch?v=BExo2T_D6pY
  14. riton
    riton Active Member
    1,006Coins
    new video with sim x 2.1.04 beta
    I always the problem: simulator disconnect, or X sim disconnect and stop the simulator....
    the simulator stop alone, is painful!
    have you a solution for this problem that has lasted long with me?
    thank you
    http://www.youtube.com/watch?v=HBJ3BosKfts
  15. riton
    riton Active Member
    1,006Coins
    some pictures of the progression:
    I painted the simulator, and I make over the top of the simulator.
    I make a frame to stiffen the bottom of the simulator
  16. riton
    riton Active Member
    1,006Coins
    news:
  17. treeman7199
    treeman7199 New Member
    0Coins
    Sweet! I like it
  18. riton
    riton Active Member
    1,006Coins
    News:
    blasting and painting, the end soon!
  19. riton
    riton Active Member
    1,006Coins
  20. skarvsladden
    skarvsladden New Member
    0Coins
    Nice Platform!
    Do you use inverters?
    Do you use an analog input to the inverters?
    I have inverters on my motion controller.
    I uses 0-5V input ,an must use -100% in dynamical speed control for both left and right direction to get my motion running smootly.
