Showroom Compact AC Servo 6DOF Rotary Stewart platform
Discussion in 'DIY Motion Simulator Projects' started by knaufinator, May 26, 2020.
  1. knaufinator
    knaufinator Active Member
    Simulation Engineer
    akron,ohio
    1,929Coins
    AC motor, 6DOF
    A compact 6DOF platform I have been designing/building for the last 2 years, wanted to finally get it properly documented here, as I used this site as a wonderful resource that help guide me to my ultimate design. The design focuses on being compact in size yet still toss a rider around like a ragdoll...
    Rotary Stewart Platform using 6 - 750 W AC servo motors w/50:1 high precision planetary gears.
    Custom PCB that hosts a ESP32 microcontroller for interfacing and controlling of the motors.
    It's also very much so... Bolted to the concrete floor!! It would leap into the air majestically otherwise
    The project is on Github, PCB, platform code and major parts used, so to help anyone else in their hunt.
    https://github.com/knaufinator/6DOF-Rotary-Stewart-Motion-Simulator
    My Youtube Channel - Subscribe!
    https://www.youtube.com/channel/UCm_IVsEpLjsR-aZIYZF6-_Q
    Overview of platform
    iRacing
    GTAV
    NoLimits 2
    Dirt 2.0
    • Winner Winner x 12
    • Like Like x 8
  2. knaufinator
    Simulation Engineer
    akron,ohio
    1,929Coins
    AC motor, 6DOF
    Build Album
    Chassis was created around the seat itself
    Threaded bungs held in place by a jig
    Eye balling orientation
    Welding the Chassis to the bungs
    More,.. Eye balling orientation
    First mating of my gear and motor trial
    Imagining more motors and lots of more work to do....
    Coped tube ends so they can be welded as cleanly as possible
    Seat bracket made, all that eye ballin payed off...
    Prevent rust, paint protection.
    mocking up pedal box area and slope
    Test mounting of pedals for sizing chassis
    Pedal Bracket start
    Helper
    Pedal Bracket END!
    Welding up the bottom pedal box brace
    Back in place on the jig for more modifications
    Welded Pedal bracket onto chassis bottom brace
    First arm assembly - with High misalignment heim joints
    Welded up the top section of the chassis that will hold the monitor and wheel
    Shifter, custom ebrake, and tiny keyboard solidly attached...
    Tactile transducer bracket...
    Tactile transducer bolted to frame of seat
    Newer gear(less backlash)/servo sitting on a 100 pound steel plate
    Fabricating Gear bracket 1/4" steel plate
    Welded first Gear bracket onto steel plate
    2x3 inch steel rectangular tube, to lift the platform off the ground
    Mocking up the bottom feet area,.
    Gear/motor in place on base for first time -- Giggidy,..
    Needed the base to be higher than the rectangle tube would allow, thick steel tubing for an extra few inches
    Pre welding mock up
    Welded and painted
    Gear bracket support added so no flex occurs
    More Brackets
    More welding
    oh snap,..This is pretty
    Rust protection!
    First swing arm in place 7 1/4" long
    Got a tiny server case to use to mount all of the AC Servo power supplies.. now to figure out how to stuff it all in there...
    Running the wires for 220v and distribution blocks
    Filling it UP!
    Swing arm production line...
    AC Servo control box all wired up and TURNED ON!!!!
    All motors mounted for first time
    Adding threaded bungs to the swing arm for attaching the chassis platform/arms
    Lifting the base onto the threaded anchors in the cement floor. using a car jack...
    By this time I needed to mod the wheel area for a new Fanatec wheel,... so I hacked of what I did to start over
    Welded a extension on to chassis for Fanatec wheel
    Blower Fan with 90 degree (car air intake) tube for wind feels
    Rear surround speakers
    Oh look,.. its almost done,... Giggidy...
    Monitor bracket, welded to chassis. (Universal Vesa mount, then I took a angle grinder to it to get the piece i wanted...)
    Magnetic limit switch installed
    Beauty shot of the motor base
    "My muse my flame"
    Green screen room!!!
    Needed a room for the rig, May as well make it green!
    Small monitor attached below the main monitor for SimHub, or video recording display
    • Like Like x 11
    • Winner Winner x 3
  3. Thanos
    Electronics Engineer
    2,908Coins
    Nice!! Welcome!
  4. Petertje
    Petertje “Engineering changes the world.” —Isaac Asimov
    Mechanical engineer / battery specialist
    The Netherlands
    447Coins
    I'm working on a linear 6dof setup, but this looks good too! Nice video's!
  5. Thanos
    2,908Coins
    Be sure to mention that the platform is bolted on the floor... :cheers
  6. knaufinator
    Simulation Engineer
    akron,ohio
    1,929Coins
    AC motor, 6DOF
    Lol, post updated!
  7. knaufinator
    Simulation Engineer
    akron,ohio
    1,929Coins
    AC motor, 6DOF
    I recently added a solid monitor bracket to the motion rig, made a time lapse of the process.
    I have ordered 2 new 50:1 gear boxes to replace the 2 gear boxes I have in the rear. They are older and have more backlash than the rest, 12 arcmin vs 5 arcmin... its enough of a difference ... to get me to spend 500 on replacing them,... in the name of perfection.
  8. frsim09
    frsim09 Member
    Ariège, France
    604Coins
    Congratulations :thumbs, very nice achievement , Thank you for this sharing
  9. knaufinator
    Simulation Engineer
    akron,ohio
    1,929Coins
    AC motor, 6DOF
    GT Legends tuned up and ready to go.
  10. knaufinator
    Simulation Engineer
    akron,ohio
    1,929Coins
    AC motor, 6DOF
    I want to build a Cobra kit car,.. so I am getting my practice in
  11. MarkusB
    4,215Coins
    You have really created a fantastic piece of hardware. Congratulations!
    I also love your green screen videos. My favorite is the rollercoaster ride in this post, where I get the impression that your rig does indeed sit on the rails. Amazing!
  12. knaufinator
    Simulation Engineer
    akron,ohio
    1,929Coins
    AC motor, 6DOF
    Thank you!, compliments never get old!
  13. thefost
    thefost Member
    242Coins
    Love the sim! Was wondering how you liked the reclined position for your rig, is it optimal for you or would you prefer a different geometry if you did it all over again? I'm considering doing a similarly reclined rig only with actuators and your rig looks like a good place to start copying =)
  14. knaufinator
    Simulation Engineer
    akron,ohio
    1,929Coins
    AC motor, 6DOF
    Thanks!, The reclined position was intended to balance the load out as much as possible when a rider is in the seat, to counter balance the mass of the monitor/pedal box area. Once you are in place, the reclined position feels natural, and I would do it the same or similar if I was to do this again.
  15. hooshang
    hooshang Active Member
    275Coins
    good job:cheers
  16. hooshang
    275Coins
    IMO your cranks are a little long,dont you have any problem with your motors power for lifting.
    anyhow nice setup mate...
    :thumbs
  17. knaufinator
    Simulation Engineer
    akron,ohio
    1,929Coins
    AC motor, 6DOF
    Not at all, the longer the swing arm, the more movement I could get out of it. I first did quite a bit of testing to make sure that a motor/gear could handle the weight... I found that a single motor/gear could lift a rider ~14 inches in less than a second, with a 7.25 inch swing arm. I am a skinny guy @ ~180lbs, but I have had dudes ~250lbs in the rig and it handling just the same.
  18. hooshang
    275Coins
    good mate.i calculate you have more than 715 N turq at the tip of any actuators,
  19. knaufinator
    Simulation Engineer
    akron,ohio
    1,929Coins
    AC motor, 6DOF
    • Funny Funny x 2
  20. hooshang
    275Coins
    nice green box.i think this is the first time in this community such a video to show clear rig motion with the game:thumbs
