Codemasters F1 2019 plugin v2.0.1
SimTools plugin for Codemasters F1 2019
  1. nornesnaj
    nornesnaj New Member
    Netherlands, Zelhem
    125Coins
    Motion platform, 4DOF
    There are no other apps running
  2. Trigen
    Trigen Active Member
    2,872Coins
    Not working in Simtools or PT mover. Simhub is receiving and my buttkickers are fine. Tried all options. Have completed a race and installed patch. Pt mver tried before patch and says show connecte but no data.
    Seems game engine and manager is not connecting properly and needs updating. The game is a mess though but seems to be the plugins that needs updating since simhub is fine.
  3. bruno1210
    bruno1210 schumi06
    103Coins
    UDP FORMAT legacy mode NOT 2019
  4. Renoboss
    Renoboss Member SimAxe Beta Tester Gold Contributor
    Work, Motion Simulator and High Tech Fishing
    Netherlands (Frisian)
    297Coins
    2DOF, SCN5
    Hi Trigen,
    Only run in DX-11.
    UDP format has to be set at "Legacy".
    You will loose output in all other (Simhub / buttkickers)
    I tried everything to get it running but no luck.
    Even with "Codemaster Proxy Server" and "Sim Racing Proxy Server" it can not be done.
    Simtools needs to get an F1 2019 plugin for at least UDP 2019 compatibility.
    Sick of waiting and not being able myself to make a plugin i ended up buying Motion Max Manager Frex Edition.
    Runs like a charme !!!!
  5. bruno1210
    bruno1210 schumi06
    103Coins
    Hello again,
    I run simtools and simhub at the same time you just have to modify a file in simhub.
  6. bruno1210
    bruno1210 schumi06
    103Coins
    SIMHUB AND SIMTOOLS
  7. Trigen
    2,872Coins
    Got it working thanks.
  8. nornesnaj
    Netherlands, Zelhem
    125Coins
    Still not working only when i use the simhub F1-2017 i get some info but info like DRS etc still missing.
    and id will do nothing if i select simhub F1-2019. any more information ?
  9. bruno1210
    bruno1210 schumi06
    103Coins
    simhub f1 2017 works correctly in f1 2019 games with legacy telemetry and simhub works only with f1 2019 telemetry
  10. Newgun
    Newgun Member Gold Contributor
    77Coins
    AC motor, 4DOF
    Will we ever get the plugin with UDP 2019 using DX12?
    Hoping to use either SLImax Dash or Simhub dash, both of which works only with UDP 2019.
  11. ludo22420
    ludo22420 Member
    206Coins
    does the plugin work with ps4?
    150,956Coins
    +11,025 / 56 / -2
  13. iLLuac4
    iLLuac4 Active Member
    890Coins
    Hi. I have tried today all options and the plugin does not cooperate with SimHub and SimTools at the same time no matter what I do. It works only with SimTools.
    Will there be an update for dx12? Hope so.
  14. Andreawrc83
    Andreawrc83 Andywrc Gold Contributor
    commerciante
    italia
    73Coins
    Are there news for dx12 plugin of f1 2019? I need it :( Please is also not possible to have plugin? Dashboard don't go good with the legacy mod.
  15. cgodwin
    cgodwin Active Member
    Engineer
    Eugene, Oregon
    2,478Coins
    Dumb question, but how do I run the game in DX11 mode? I can't seem to find that option anywhere.
  16. Daguru
    Kitchen installer
    Wales uk
    454Coins
    Motion platform
    not tested by me but go into steam and F1 2019 properties, in the launch options type -force-d3d11
  17. Andreawrc83
    commerciante
    italia
    73Coins
    You must open the game with steam, in f1 2019 you click play and you can see one window where you can select dx11 mode
  18. nornesnaj
    Netherlands, Zelhem
    125Coins
    i now use FlyPt for F1-2019 with dasboard. works fine
  19. Andreawrc83
    commerciante
    italia
    73Coins
    Thanks, i must only download flypt or i must download any file for f1 2019 dx12?
  20. nornesnaj
    Netherlands, Zelhem
    125Coins
    you only need to download the latest FLYPT there are some example files in the download.
    i use a pt actuator set so only had to change the so called sorce from iracing to F1-2019.
