FlyPT Mover 3.5.3
  1. hexpod
    hexpod http://heXpod.xyz
    berlin
    7,770Coins
    DC motor, 6DOF
    ....and here I change the period from 7s to 2s :
  2. Arthur SCHOOR
    Arthur SCHOOR New Member
    64Coins
    I have the flight simulator x Deluxe (not the SE). It works or not ? I have test a lot of things but its not works...
    I search a "light" flight simulator compatible....
    Sincerly, Thanks a lot for your (hard) work on FlyPt !!!!
  3. Arthur SCHOOR
    64Coins
    I juste see the New "source manual" and i have try but its not works... Maybe i have do too much test ... I reset the config ans i retest ...
  4. pmvcda
    15,503Coins
    It should work.
    But it needs some updates to get on the same level of p3d.
    I'm updating sources right now, and will do it for fsx.
    Try to setup the source, and maybe wait for the next build.
    I want to release in the next two days, if possible tomorrow.
  5. cfischer
    Colorado
    2,783Coins
    Love all the hard work!
    Any idea when this might be available?
    I'm sitting here thinking of how cool it would be to add or remove the gain of suspension motion with the increase or decrease of heave in Dirt Rally 2.
    edit: this project of yours is turning into a monster! I can't believe you are doing this all by yourself.
  6. cfischer
    Colorado
    2,783Coins
    By the way, I found a small bug in the last 6 hours I've been using the player. Such a brilliant and easy to use tool. I noticed mover crashes a lot when I let the recording play all the way to the end (loop has been unchecked). For the last 2 hours I have been stopping the recording manually and no more crashing.
    Not a big deal.
  7. pmvcda
    15,503Coins
    Have to get deeper into that yet.
    But I have thought already in how to get that working, but for all variables and filters.
    And it's not so simple as I thought.
    I have the code almost ready, but the final implementation can bring lot's of problems.
    I can do it easily for one module/value and I have something behaving a bit like that already in the type of surface (not available in Dirt Rally 2) and other variables like stall in air crafts.
    It's in RFactor2 I think (so many already that I start to mix them) PCARS2 and FSX/P3D.
    Generated vibration depends on speed and surface type for each wheel.
    But it's hidden from the user filters.
    What I have mostly done is something like having filters working like:
    GAIN(SUSPENSION_TRAVEL;SPEED)
    So, it's the use of other values in the filters. What we have here is a kind of scripting.
    And while the interpreter is ready to be adapted and the keywords are already in, this is subject to lot's of possible errors.
    It will be the nerd mode :)
    I did not forget about it. :thumbs
  8. pmvcda
    15,503Coins
    Is that in the last version -> 2.9.8?
  9. cfischer
    Colorado
    2,783Coins
    Yes, should have mentioned. 2.9.8
    ps I love nerd mode.
  10. Flymen
    Montreal, Canada
    2,434Coins
    DC motor, 6DOF
    Hi ,everybody
    I would like to know , where can we exchange our Flypt mover set up on this site(xsimulator ) .. for different game. Exemple: nolimits 2 (tcp) id17 / simple direct wind .
  11. Gabor Pittner
    Gabor Pittner Active Member
    Szekesfehervar Hungary
    1,395Coins
    Here is the profile you made. Riding on the FA/18C Hornet around the Carrier.
    It feels good, very good. :thumbs
  12. robjos1
    robjos1 Member
    Flying about
    United Kingdom
    30Coins
    That looks darn incredible!! Epic setup.. probably better than a lot of real F18 training sims
  13. hexpod
    berlin
    7,770Coins
    DC motor, 6DOF
    Cool !
    I see the image from the pimax doesn’t seems really smooth. Do you feel any disturbance on visual side ?
  14. Antonio Iannotta
    Antonio Iannotta New Member Gold Contributor
    Machinist
    - 34Coins
    AC motor, 6DOF
    Hello, I downloaded FLYPT mover plugin, I installed it in the plugin updater but it doesn't show up, am I doing something wrong? I downloaded the rotating hexapod and that works.
  15. Gabor Pittner
    1,395Coins
    I think you see it when my head is shaking as the actuators change direction hard. Sometimes its too hard.
    However I dont feel bad at all. The Pimax offical motion cancellation works very well, there are some issues but will improve.
    For example a smoothing function will be added to the motion compensation to allow the user to tune out small vibrations from motion rigs. Now they are noticable sometimes, especially in racing games.
    The motion compensation works well for me but this would be an improvement.
    EDIT:
    Moreover the HMD works at 64Hz with smart smoothing so its 32fps...o_O
    Maybe with the next generation GPU (3080Ti) will be better...
    But I have to say its not bad at all...
  16. hexpod
    berlin
    7,770Coins
    DC motor, 6DOF
    Only when you’re stopped on the carrier, the game should send huge negative deceleration which should be transcribed in surge fast back jolt and negative pitch from the mix channel.
    I can’t see this negative pitch. Why is that ?
  17. Gabor Pittner
    1,395Coins
    Yes you are right. Im not finished the pose setup for ground. There were a huge and hard heave, so I reduced range and gain to a half of them, and both mix channel was unchecked, so it didn't work.
    You know if you make a mistake the landing procedure it would hurt...:grin I want to get a nice feeling but it should be safe enough :grin
    EDIT: Here is a pose for ground... however its for a car :grin:grin
  18. Arthur SCHOOR
    64Coins
  19. nornesnaj
    nornesnaj New Member
    Netherlands, Zelhem
    125Coins
    Motion platform, 4DOF
    Hi i am trying flypt mover with RF2 but it seems its not connecting the source to the game.
    Am i missing someting ?
  20. pmvcda
    15,503Coins
    Did you copy the DLL to the plugins folder?
    Look inside the Manuals, there's a guide on how to do it. (sources)
