FlyPT Mover 3.5.3
  1. SimMeInMD
    SimMeInMD Member
    Baltimore MD (USA)
    266Coins
    @hexpod yes as far as I know Pitch is the only thing reversed.. Youre saying to put a - in front of what value? Sorry for the complete newb question but I learn by doing not listening :(
  2. hexpod
    hexpod http://heXpod.xyz
    berlin
    7,839Coins
    DC motor, 6DOF
    Is your platform a 6-dof ?
  3. SimMeInMD
    SimMeInMD Member
    Baltimore MD (USA)
    266Coins
  4. hexpod
    berlin
    7,839Coins
    DC motor, 6DOF
    Very strange.
    If you use front as rear, roll surge and sway should also be inverted.
    Could you post your config file and a picture of the hardware?
  5. SimMeInMD
    SimMeInMD Member
    Baltimore MD (USA)
    266Coins
    @hexpod... Which way should the rig tilt on - roll and -sway? As of now the rig tilts to the left when negative and sway goes to the left as well when negative. Surge is to the rear when negative also.
  6. SimMeInMD
    SimMeInMD Member
    Baltimore MD (USA)
    266Coins
    @hexpod ... GOT IT! For anyone looking to reverse their direction all you have to do is put a - in front of the (OUT Gain/Flip) which is in the first post of this thread!!
    After reading it over again I noticed it and BOOM done! :)
  7. hexpod
    berlin
    7,839Coins
    DC motor, 6DOF
    This is what I have, plz. describe what’s different in your rig.
  8. Trigen
    Trigen Active Member
    2,891Coins
    Having some issues with the F1 2019 plugin. Not receiving any telemetry in the plugin but Simhub works fine for my buttkickers. Tried all in game settings
    Nvm, Simhub was in the way
    Edit. Seems to not work right. Im getting a lot of spikes in lateral acceleration etc and while i get long/vert/Lat accel with gravity and have only those enable the spikes will move my flaps but with gravity does not. Trough simtools it works fine. Maybe cause its using legacy mode and Mover 2019
  9. pmvcda
    15,702Coins
    I will take a look at it.
    I'm working in a new update and put this in the list.
    By the way, you can forward the ports in Mover or Simhub, to use data in another program.
  10. Trigen
    2,891Coins
    Thanks. Ill just use simtools for now and forward the ports trough simhub to simtools and use it as a source
  11. Trigen
    2,891Coins
    Here's a recording of the F1 2019 inputs im getting.
  12. Trigen
    2,891Coins
    Ok, seems i jumped the gun a little. The issue seems to be when the game is in 1920 window mode the telemetry is completely whack. In fullscreen and window 5760x1080 its fine. Its not that surprising given this game is riddled with bugs.
  13. pmvcda
    15,702Coins
    Try to hide all modules from Mover to see if that solves the problem.
    Honestly, I did no test F1 2019 that much...
  14. Trigen
    2,891Coins
    Ok so ive tested single screen without nvidia surround. Does not work in full screen or windowed.
    Turned back to 5760 full screen and windowed and it worked fine. Getting all values of later acc and lateral acc with gravity etc. Thankfully i only play with triples.
    1920x1080
    Tried to hide all, no change.
    Tried to minimize, no change.
    Tried to keep it under the game window no change.
  15. pmvcda
    15,702Coins
    Can't think of a reason for this to be a problem with Mover (can be, but don't know how for now).
    Is that happening with SimTools?
    Can you try it with high and low resolution calculation time?
  16. Trigen
    2,891Coins
    I've been testing a bit and there's no issues with simtools but they use legacy mode and not 2019 telemetry. I'm in the same opinion as you that its the game and not Mover as that's just to unlikely considering how many bugs there are in this game. Its been nothing but a headache of epic proportions. Also since its working in triples its really no other conclusion that its a game bug.
  17. Trigen
    2,891Coins
    Anyone that can help me out setting up UDP to a second computer? unsure on how to set it up and what needs to be installed or changed in ardunio. Ive set the port, forwarded on the router.
  18. Arthur SCHOOR
    Arthur SCHOOR New Member
    64Coins
    Hi, FlyPt is juste a dream ! Its a very nice sort !!
    i have a question. Whats the process to make a New source for a game that simtools and FlyPt not make today (dirt rallye 2 (not 2.0 just 2 ;) )
    Thanks everyone !!
  19. pmvcda
    15,702Coins
    For now it's closed, it has to be me, code is not stable enough to make plugins.
    And, I'm not thinking of plugins, I want to make it easier to use ;)
    But what do you want, Dirt Rally 2 not 2.0? What is that?
    Dirt Rally is already included in Mover, for version 1 and 2:
  20. pmvcda
    15,702Coins
    You want to run game in one pc and Mover in another pc?
    If so, to use serial, Mover needs to be in the same pc you connect the serial.
    Only UDP sources can work like that.
    You have to setup the game to send data to the pc where you have Mover.
    For that keep the port and change the IP.
    If you have it setup in the router and firewalls, it should work.
