3DOF aluminium profile simulator
Discussion in 'DIY Motion Simulator Projects' started by tomkil192, Mar 28, 2020.
  1. tomkil192
    tomkil192 Member
    Uk. London
    - 24Coins
    Hi All.
    It has been a while when I started planning my simulator. Finally, I have time to put it all together. (I think under recent circumstances more people will finish theirs dream projects )
    My Rig plan:
    3 Dof with motors at the back
    Frame - Aluminium profile 80/40
    Drives - Moto monster H bridge
    Motors – Wheelchair motors 24V
    Power supply - 12V server supply HP (should be enough for start)
    Controller - Arduino UNO
    Potentiometer - 10K normal (upgrade to hall sensors once they are back in stock)
    Wheel - Thrustmaster Ts300
    So far so good, reading the forum and learning as it goes.
    Today I have had some movement (its ALIVE!!!!) but its to soon to make a video..
    Some photos belowFeel free to make some comments and advises.
    20200327_154427.jpg 20200327_154440.jpg 20200327_154511.jpg 20200327_154527.jpg 20200328_155506.jpg 20200328_184058.jpg
    153,866Coins
    +11,153 / 57 / -2
  3. tomkil192
    tomkil192 Member
    Uk. London
    - 24Coins
    Thanks Noorbeast.
    Already prepared some radiators and i am aware of cooling mm's. I was thinking to add radiator on the bottom with the thermal tape and then bigger one on top. I will send some photos tomorrow. In that case i should be able to also cool down the board (underneath). Good idea?
    Tom
    153,866Coins
    +11,153 / 57 / -2
    Not sure about MMS, but JRKs can effectively cooled from underneath, here is how @Zed went about it: https://www.xsimulator.net/community/threads/jrk-12v12-overheating.10327/#post-133739
  5. tomkil192
    tomkil192 Member
    Uk. London
    - 24Coins
    Temporary cooling solution. I am running the rig on PWMmax 200 and its not even warm.
    Btw i need to send you a screenshot with my motors parameters because i am not 100% sure if they are correct.
  6. tomkil192
    tomkil192 Member
    Uk. London
    - 24Coins
    Ok. Just got my licence. Now I need to earn few more coints to download the Asetto Corsa pluggin :). LFS is great but i am waiting for the Nurburging ride!
    I will add some more photos tomorrow
  7. Daniferias
    Daniferias Member
    392Coins
    Enhorabuena por tu nueva licencia,tu proyecto me gusta,y tiene buena pinta,la mecánica del mío la tengo parada,ya que no puedo ir al trabajo por la situación en España,estoy comprendiendo el sistema entre Arduino y simtools, smc3 y demás.disfruta y seguiré tus avances que seguro algo me aclararas.gracias por aportar
    153,866Coins
    +11,153 / 57 / -2
    Please be aware that you can dual language post but it is a forum requirement to include English via Google Translate: https://www.xsimulator.net/community/threads/forum-rules.9527/
    We have bi-lingual speakers from many different language groups, so if Google Translate really messes it up they can help clarify what was intended.
  9. tomkil192
    tomkil192 Member
    Uk. London
    - 24Coins
    Noorbeast. Its hard to answer in spanish.. :)
  10. tomkil192
    tomkil192 Member
    Uk. London
    - 24Coins
    Could someone check my SMC3 settings please.
    Why my PMW (yellow line) is so erratic? Is this due to no shield? (at the moment i have a spider connection and no earth.
    Any advice welcomes.
    BTW. Nürburgring on AC feels so good. I can't wait to add traction.... :)
    Thanks to everyone!
    and bigger Tankst to people who started xsimulator page! RESPECT
  11. tomkil192
    tomkil192 Member
    Uk. London
    - 24Coins
    153,866Coins
    +11,153 / 57 / -2
  13. Squarebob
    Squarebob Member Gold Contributor
    Georgia USA
    70Coins
    DC motor, Arduino, 4DOF
    Wow that framework is really nice. Keep up the quality work and keep the pictures coming.
  14. tomkil192
    tomkil192 Member
    Uk. London
    - 24Coins
    thank you. I will update you with more photos today!
  15. czgui
    czgui Member
    - 110Coins
  16. noorbeast
    153,866Coins
    +11,153 / 57 / -2
    A 120 or 180 Hall sensor will give better resolution.
  17. Squarebob
    Georgia USA
    70Coins
    I have chosen this 180 degree sensor
    TT Electronics 6127V1A180L.5FS hall sensors
  18. czgui
    czgui Member
    - 110Coins
    Before I bought a Hall motor, I tested the 10K potentiometer stroke and voltage change. Buy a 300 ° Hall motor in order to simulate a 10K potentiometer. For this, an extra commission was paid.
    If I knew that 120 ° and 180 ° were better, I bought this one, and the price is still low.
    It's too late to know the news, but you let me learn more.
    Thank you teacher for your guidance.
  19. tomkil192
    tomkil192 Member
    Uk. London
    - 24Coins
    Hi All,
    Its been a while since my last update... live is busy even on the quarantine :)
    Since my last visit I have added few mods and finally I am changing now the pots to farnell hall sensors.
    Quick question. Do I need to change the code in Arduino to get them to work?
    My issue is that after the swap when I start the motors in Smc3 software the motors goes over the limit
    (hall sensors are set in the middle before I start ..
    Any ideas?
  20. tomkil192
    tomkil192 Member
    Uk. London
    - 24Coins
    few photos of my rig:
    20200407_185601.jpg base model with the seat
    20200407_185658.jpg traction - 3rd motor added
    20200407_185649.jpg Wheels added
