FlyPT Mover
  1. hexpod
    hexpod http://heXpod.xyz
    berlin
    7,099Coins
    DC motor, 6DOF
    „Yaw gives negative and Sway/lateral positive in a right turn„”
    Sorry to interfere, only to say that with all cues positive, yaw gives me positive cues couter clockwise. That’s something which is not 100% intuitive but as the hardware directions matches the 3D model I am perfectly fine with it.
    If some users uses front as rear, they just have to invert everything except yaw and heave.
    EDIT:
    So the quoted sentence from above seems to me coherent in “right turn” scenario.
  2. Trigen
    Trigen Active Member
    2,826Coins
    Thanks, really appreciate you taking the time! Sadly it made no change. The values flip on the output side but the same as i were to just put a - in front of the output. WIP :)
  3. Trigen
    2,826Coins
    Sure it makes sense which is why i mention it may be needed for other things but for my application it really doesn't work. . If it can really be soled by making them both positive with a check button I cant really tell you for sure since my programming skills aren't that good. further testing seems to say no when its combine, fine on its own. Every which way i test if i set the gain a bit higher or the lateral is to low and spin to fast it will dip below 512. It looks like it need some kind of hard stop in the filters. I do of course have it in the global but it would be nice to have it. Not a high prio anyway.
    Its time to chill for today though. Ive been at it for 10 hours. I could be quite off but of course so i appreciate any and all input!
    I can also make it work like this (gain is -1.000 in the filters)but still it will pass 512 and go below so if i spin on start it will go far below and hit my clipping settings.
  4. hexpod
    berlin
    7,099Coins
    DC motor, 6DOF
    Maybe give a try with logistic filter. It could be with this function you will find a good combination for your application.
  5. Trigen
    2,826Coins
    Thanks. I've been experimenting alot with it but haven't found it that useful other than setting soft limits. Also gain does not care much about it so I have to crop it. There are some cropping options I haven't tried In elation to the main crop on yaw/sway though so it could be worth a shot.
    I had the same issue with traction loss and sway in simtools too and in the end I had to write an axis plugin with the api where I hard limited sway and traction loss. I couldn't use clipping cause it didn't work with my neg/pos heave and surge. I can use that with an axis from simtools but of course I'd prefer only using Mover. I haven't looked that much on cpu usage but I'll have to use two sources as simtools dosent have the roll speed I need so it doubles.
  6. pmvcda
    14,210Coins
    We are going to make it work. I will need it to in the future. I want to build a g system also.
    Just give me some time to see what I can do and understand better the problem.
  7. Gabor Pittner
    Gabor Pittner Active Member
    Szekesfehervar Hungary
    1,294Coins
    When I start all FlyPT outputs with the v2.8 the actuators go to middle position in 5sec slowly, and when I stop them, they go back to min position.
    With the new build, at start they go to middle as fast as they can, and after stop they stay at the middle. Do I need a start/stop string or I missed something?
  8. hexpod
    berlin
    7,099Coins
    DC motor, 6DOF
    That’s curious.
    On AMC1280USB I have the ramp functioning correctly in both senses.
  9. pmvcda
    14,210Coins
    You have to set the park/rest/default position of the rig in the rig module.
    Zero is the middle of the actuator, put there the minimum for the actuators ( in all actuators).
    In the above image I would use -200 in all actuators to have them in the lowest position (it's the range of the actuator).
  10. Gabor Pittner
    1,294Coins
    Thats it!!! Thanks!!! hug:
  11. Gabor Pittner
    1,294Coins
    But I don't have Thanos board anymore...:rolleyes: I sold my complete rig with rotation actuators and controller too. So now I have an original FlyPT motion rig with linear actuators controlled by ESP32 boards :cool:
    Thats another level of motion rig.
  12. hexpod
    berlin
    7,099Coins
    DC motor, 6DOF
    -200 ? What is the unit there ?
  13. pmvcda
    14,210Coins
    mm or degrees
  14. Flymen
    Montreal, Canada
    2,415Coins
    DC motor, 6DOF
    Hi , @pmvcda I would like to try my new set up ( wind simulator ) with your program ( flypt mover) .
    It's will be with Arduino uno card 0-5 v pwm .
    Q- Witch programm or code I must use for this to drive this card arduino with Flypt Mover set up ?
    Set up flypt mover exemple : Source No limits2 ( speed ) , Directs source value ( speed) Key : wind , Output port com3 for arduino , .....missing something ......I'm lost a bit !!
    Thanks !
  15. pmvcda
    14,210Coins
    I'm on the phone now, give me some hours and I post an example
  16. hexpod
    berlin
    7,099Coins
    DC motor, 6DOF
    Sorry I don’t fully understand.
    So in this case -100 (bit 2978) is an angle from the mid pos ? If I change mid pos. The bit output doesn’t change.
    Or it’s 100mm from the platform height ?
  17. pmvcda
    14,210Coins
    Hmmm,
    Should be - 100°
    -100 is the angle from the mid position.
    The middle is the default position, zero.
    So having the actuator at it's zero position (middle) should output the middle value of the bit range (32767 in your case)
    Now we specify the rotation range to each side of the middle. In your case 110º.
    So bit value of 0 is middle - 110º and maximum value of bit range is at middle + 110º.
    It's all relative to the middle position
  18. hexpod
    berlin
    7,099Coins
    DC motor, 6DOF
    I think I understand but it this case if you change the mid position this value should be updated. Right ?
  19. pmvcda
    14,210Coins
    No because it's relative to that position
  20. hexpod
    berlin
    7,099Coins
    DC motor, 6DOF
    To be clear, my case is a bit specific because I am using 360 pos. sensors with a 0,5 ratio.
    The example picture I sent is not related to my case but still the fact it is not updating gives me unreasonable values.
    Maybe it takes a default mid range (if I recall it’s 30deg.) without updating it.
