FlyPT Mover
  1. Peacemaker105
    Perth, Aus
    1,977Coins
    Thanks for that. I must of missed this image along the way, i ended up swapping the motors around to get it going, which is exactly what you just said :)
    I managed to get a run in with No Limits but i was struggling to get the filters right. When it does a barrel roll it has a big jump coming out of the roll.. Looks like i've managed to get the right filter combination now going by the latest 3d mover simulations i've been running so hopefully run it through the rig tomorrow and if all goes well, sit in the thing :)
  2. benmax
    1,551Coins
    Hi Flypt ,
    I would like to know if it’s possible to use LFS in demo mode using your direct plugin .
    I tested with your plugin via UDP but no data sent . Did i have to setup something in the game or in DEMO mode i can’t recieve data from game ?
    Thx !
  3. pmvcda
    14,210Coins
    Yes you can, but you have to:
    Run a race in LFS first, to generate the config files
    Next you have to edit the LFS\cfg.txt (in the LFS folder).
    Look for OutSim and replace those lines with:
    OutSim Mode 2
    OutSim Delay 1
    OutSim IP 127.0.0.1
    OutSim Port 4123
    OutSim ID 1
    OutGauge Mode 2
    OutGauge Delay 1
    OutGauge IP 127.0.0.1
    OutGauge Port 4124
    OutGauge ID 1
    Should work now.
  4. benmax
    1,551Coins
    Thx !
    Will give a try and report here .
  5. benmax
    1,551Coins
    Yes Thx works great ... I will test my actuator . I 'm building a gseat system based on your electronics . I designed a pneumatic actuator and i use air to inflate or deflate '' wedge '' pump system !
    I will mount this on my 6dof sim one actuator for longitudinal acceleration and 2 other actuators for lateral acceleration left and right . I already have a belt tensioner system with springs that i have to improve also !
  6. Trigen
    Trigen Active Member
    2,826Coins
    One thing, Ive never really been able to get a feel for hitting curbs with simtools. I suppose its due to heave relating to the whole car and not getting left and right vertical movement. You have roll and pitch but it dont really give the desired effect. Is that something thats possible in Mover? Im thinking about using the suspension speed data and multiply the value as they are quite small then rounding it to reduce small spikes but im not quite sure how to multiply and use the add and logistic filter with it to soft stop it in a certain range as i dont want negative values
    Another thing. Is it possible to copy and paste anything?
  7. Peacemaker105
    Perth, Aus
    1,977Coins
    Is there a trick to get the yaw data from Dirt 2.0? mines not receiving any at all? :(
  8. benmax
    1,551Coins
    If you want this kind of effect hitting bumper and the car jumping left or right , with mover you have to use the roll speed . Using Roll speed you will have this feeling only right or left lifting . Try first to disable all effects and setup roll speed and test .
  9. Trigen
    2,826Coins
    Thanks for the suggestion. The feeling is absolutely EPIC! I'd highly recommend trying this to anyone with a G seat. Then go hit the curbs at Nordschleife. This adds another dimension really and , now i got heave in the roll direction too and i can feel the car so much better. Also thanks to flyPT for creating this awesome software!
  10. Trigen
    2,826Coins
    Is there a way to simulate traction loss at the moment or do i need to wait for 2.9 with the spesific filter? Which force would i use for current testing?
  11. Marco Annunziata
    646Coins
    Hello everybody,
    I'm facing some troubles connecting the source SymTools 2 to SymTools. When I click on "connect" nothing happens but its works fine with "Assetto Corsa" and "LFS" sources.
    Am forgotting something?
    Thank you all
  12. pmvcda
    14,210Coins
    You need to install the Simtools plugin to connect with Mover.
    The DLL is in the download.
    See here: https://www.xsimulator.net/community/threads/flypt-mover.13464/page-3#post-180938
  13. Marco Annunziata
    646Coins
    Thank you for the answer but something escapes me. I have download the Simtools plugin and I can connect the FlyPT to SimTool Game Engine Like in the picture linked below:
    https://www.xsimulator.net/community/attachments/sem-nome-jpg.63630/
    My doubt is how to connect the Source connector to SimTool like in link below
    https://www.xsimulator.net/community/attachments/sem-nome-jpg.63632/
    If I push the Connect button it doesn't become "Connected" like in the picture
  14. pmvcda
    14,210Coins
    Did you make the axis assignment?
  15. Marco Annunziata
    646Coins
    Yes I did, please take a look to the attachment below
  16. pmvcda
    14,210Coins
    That's strange.
    You are in 2.8 right?
  17. Marco Annunziata
    646Coins
    Yes, correct 2.8.0
  18. Nisch
    Nisch Member Gold Contributor
    Software Developer
    Phoenix, AZ
    266Coins
    With 2.8, I've sometimes had to turn on my test output in Simtools and then manually click "Connect" in Mover and then the connection remains. Otherwise, I can't seem to get it to connect automatically after a reboot.
  19. Marco Annunziata
    646Coins
    Hello Nisch,
    I've tried but seems doesn't work
  20. robjos1
    robjos1 Member
    Flying about
    United Kingdom
    30Coins
    Any news on V2.9? Looking forward to testing it out soon. Thanks for all your work as ever
