Question Epic Rollercoaster
Discussion in 'SimTools Plugins' started by DarkHunter82, Jan 14, 2020.
  1. DarkHunter82
    DarkHunter82 New Member
    96Coins
    Hello.... Finally epic Rollercoaster have the telemetry with new update....
    I have this parameters... How can we use it?
    https://bitbucket.org/snippets/b4t/7nznaa
    Thank you
    145,124Coins
    +10,779 / 52 / -2
  3. value1
    14,509Coins
    @DarkHunter82
    With the code given in your example above, it should be relatively easy to modify the LFS example plugin. You can give it a try. I'm currently travelling w/o access to my PC.
  4. DarkHunter82
    96Coins
    @value1 thank you for your reply.... The code is released from the game's developer.... I'll try to modify the LFS example plugin....
  5. yobuddy
    48,214Coins
    I can take a look in a few days also.
    Just finishing up a cool new feature for the Video Ride Creator.
    Take care,
  6. value1
    14,509Coins
    @DarkHunter82: Here we are. I think the data provided by the game is not very accurate.
    Give the plugin a try and let me know.
    Kind regards
    You must specify a launch option in the game in Steam (similar to NoLimits Rollercoaster 2)
    -telemetry network -port 4123
    -telemetry network -ip 192.0.0.xyz -port 4123
    (in case the program and GameEngine do not run on the same PC).
  7. Bruno Rocha
    Bruno Rocha New Member
    128Coins
    It didn't work for me
  8. Leandro Kemp
    Brasil
    - 10Coins
    Hello.
    Which version of the game work on?
    My version: BuildID 4583346
    In the free version and in the paid version. I put values in the tunning center, but no data is received.
    Game Runnung appears, but does not move.
    Do you need to configure any Steam startup options similar to "--telemetry" in NoLimits Rollercoaster 2?
    I await some help.
    Tank You.
  9. value1
    14,509Coins
    Oops!
    Sorry, I forgot to mention: you must specify a launch option in the game in Steam (similar to NoLimits Rollercoaster 2)
  10. Leandro Kemp
    Brasil
    - 10Coins
    It's on the same PC.
    I typed this ( -telemetry network ) and still it doesn't receive data.
    It also didn't work with my pc's ip. " -telemetry network -ip 192.168.x.yz "
  11. value1
    14,509Coins
    Oops, again. I wasn't near my PC when I wrote the post above.
    It's -telemetry network -port 4123.
    That should work :)
  12. Bruno Rocha
    128Coins
    It worked. Thank you
  13. Skel
    Skel New Member Gold Contributor
    India
    - 134Coins
    2DOF, SimforceGT, Motion platform
    not working for me, my build version is correct. Still not receiving data.
    Any help? An I doing something wrong
  14. kachepin
    kachepin New Member
    catalunya
    - 1Coins
    hello , not found for mi ... help please , thanks
    145,124Coins
    +10,779 / 52 / -2
    Unfortunately your comment does not provide enough detail or context for members to provide useful assistance.
  16. kachepin
    kachepin New Member
    catalunya
    - 1Coins
    Hola, lo siento, he hecho todo lo que dice y no me funciona, la ejecución del juego está activada pero no se reciben datos de telemetría, ¿puede ser un problema que lo use con Oculus ...? También intenté abrir con Steam poniendo la configuración que esta publicación, y también traté de crear un ícono y escribir telemetría, pero nada me funciona ...
    Una lástima para los niños de la casa sería genial y más ahora que no pueden salir de la casa ...
    Gracias
    145,124Coins
    +10,779 / 52 / -2
  18. kachepin
    kachepin New Member
    catalunya
    - 1Coins
    Hello, sorry, I have done everything it says and it does not work for me, the game execution is activated but no telemetry data is received, can it be a problem to use with Oculus ...? I also tried opening with Steam by setting the settings for this post, and I also tried to create an icon and write telemetry, but nothing works for me ... A pity for the children of the house would be great and more now that they can not leave the house ... thanks
  19. Leandro Kemp
    Brasil
    - 10Coins
    Hello.
    Does it work for the Oculus Home version game?
    Where should I change the startup options? Thank you.
  20. DarkHunter82
    96Coins
    Hello, i'm happy that this game have telemetry....with your instructions everything goes well...
    Thank you guys
