LPT1 Parallel Port problem?
Discussion in 'SimTools compatible interfaces' started by bandik, Oct 8, 2009.
  1. bandik
    bandik New Member
    1Coins
    :hi: Hello everyone, I'm new to this and I'm testing days ago it works x-simulator. I now have a correct configuration to use the outputs of the LPT1 but when I tested with the tester does not work. Press Start and viewfinder outputs are turned on and off the pins of LPT1 but really are not activated or deactivated. I have a small program to enable and disable the LPT1 output and operation and measuring and testing unit is correct. This program requires that I use to install a file called IO.dll. It is possible that for x-simulator outputs select LPT1 need additional installation of a dll file or something?
  2. bandik
    bandik New Member
    1Coins
  3. bandik
    bandik New Member
    1Coins
    It inprescindible write values in the section Using the program? I see a section in the tutorials but do not understand PARSER USING operation.
    I have not written anything, so do not function?
  4. bandik
    bandik New Member
    1Coins
    Please can someone help?. Has anyone tried the operation on the parallel port lpt1 :eek: :eek:
  5. smogf
    smogf New Member
    110Coins
    Same problem here. In Outptu analyzer all seems ok but LPT port not respond.
