Assetto Corsa Competizione Plugin 2.0.0.0
SimTools plugin for Assetto Corsa Competizione
  1. JayMonkey
    JayMonkey New Member
    40Coins
    Hummmm,
    I thought I had the latest version of Sim Tools installed but maybe not ?
    Game Dash shows Version 2.1 in the top corner of the App, but i don't see any version numbers in Game Engine or Game Manager.
    How can I check if i have Sim Tools V2.3.1 Installed ?
    Cheers
    Jay
    144,602Coins
    +10,741 / 52 / -2
    The installed version is on the SimTools splash screen.
  3. JayMonkey
    40Coins
    @noorbeast,
    Hummmm ....I never really look at the splash screen hence why i've not spotted the version number before.
    Many thanks for the tip ... :)
    Might I suggest to the devs that the version number for Game Engine and Game Manager be displayed in the top corner like it is in Game Dash ...
    Just a suggestion ...
    Cheers
    Jay
  4. JayMonkey
    40Coins
    Thanks for the tip ...
    I checked and my installed version was 2.3 .. and game dash was 2.1
    So I downloaded SimTools 2.3.1 and Game Dash 2.2 and updated my installed versions, I also re downloaded the ACC plugin and updated that just to make sure everything was up to date.
    Upon Starting ACC Game Dash was still missing the ACC in the Profile selection, eventually I figured out i needed to unpatch then re-patch ACC using Game Manager and finally was able to select the ACC profile in game dash.
    Running ACC showed telemetry data being processed by Game Dash .. I copied my dash settings from my AC profile to the ACC one and everything is now working.
    Happy Days :)
    Cheers
    Jay
  5. f1iceman
    791Coins
    2DOF, 3DOF, SCN5
    Hi all I have not been about and just fired my rig up again and I am still stuck with no motion for ACC.
    Its still the exact issue shuts down the Game Engine everytime I boot ACC.
    I have checked the ip setting when the game is not running on the ip of the game engine and that is 127.0.0.0.1 standards setting still.
    its saying the game has patched when I install it but I am abit lost now as been out of it for abit. would really like to get this up and running with acc as I have been wanting to play again for a long time now, but few things have stopped me, but I hope to be back on it again as I used to be.
    any help I would love at this stage.
    thank you all for any help in advance x
  6. f1iceman
    791Coins
    2DOF, 3DOF, SCN5
    Hi after reading up on the assetto corsa orginal I found the issue there was the same and I have deleted the files let it rebuild and it is giving motion now and not shutting the game engine down.
    thank you for all the help here and in the other areas just show how important the smallest of thing are being documented.
    I did not look at that as it was assetto not ACC but when I seen similar issue it had to be the same thing going on.
    deleted the app data and boom back in bussines.
  7. Sin.Schumi
    Sin.Schumi Member Gold Contributor
    - 48Coins
    SCN5
    With the Last Update of ACC the TL does not Work ?? I Think they change somthing in the Telemetry
  8. Roland Munz
    Roland Munz New Member Gold Contributor
    - 156Coins
    Unfortunately, I have the same problem that Traction Loss doesn‘t work anymore.
    It would be great if anyone has a Solution.
    Thanks in advance!
  9. yobuddy
    47,907Coins
    Since we are using the official API nothing should be affected by updates.
    So I believe the game publishers turned some telemetry off.
    Hopefully they will fix it in the next update..
    Take care,
  10. Foehn
    Foehn Member
    Race ; Mechanic ; Simulation
    3Coins
    3DOF, SCN6
    Hello, since the last update of this week (idem with r3e) i've some issues, is it ok for you ?
    thanks
  11. value1
    14,462Coins
    I'm running the actual Version 1.2.1 without problems, i.e. seemingly correct data in GameEngine Tuning Center, Game Dash and GameVibe Tuning Center.
    And AFAIK there was no API update since the V1.1
  12. Foehn
    Foehn Member
    3Coins
    3DOF, SCN6
    It's strange, because it's work but with bug and jerk.
    I-ve the lastest plugin release and re-installed simtool
  13. Foehn
    Foehn Member
    3Coins
    3DOF, SCN6
    the actual release is the 1.2.3
  14. Foehn
    Foehn Member
    3Coins
    3DOF, SCN6
    one more information, When i remove the patch, i retrieve a good game with more FPS
  15. Foehn
    Foehn Member
    3Coins
    3DOF, SCN6
    no gamers in AAC ?
  16. Foehn
    Foehn Member
    3Coins
    3DOF, SCN6
    No answer ?
  17. sparco
    sparco New Member Gold Contributor
    Paris
    - 143Coins
    SCN6, 4DOF
    i do...
    actuators (PRS Prosium) work in slowmo sometimes...i have to reset...
  18. Foehn
    Foehn Member
    3Coins
    3DOF, SCN6
    on another simu like RF2 Ac or Pcars, all works fine.
  19. sparco
    Paris
    - 143Coins
    SCN6, 4DOF
    i have mainly the problem on ACC
  20. Foehn
    Foehn Member
    3Coins
    3DOF, SCN6
    ok thank you for your feedback
