Showroom My 6DOF with DIY Actuators
Discussion in 'DIY Motion Simulator Projects' started by Vitalius, Sep 1, 2018.
  1. hannibal
    hannibal Active Member
    4,491Coins
    i am also working on the safety switches...!
  2. Vitalius
    Vitalius Active Member Gold Contributor
    Bonn
    540Coins
    Motion platform, 6DOF
    Cool, Soon you are so far thinking about the frames.
    I hope this week something turn off. It's hard to do anything after work.
  3. Diving Delica
    Diving Delica New Member
    Commercial Diver
    Perth, Australia
    179Coins
    Hi Vitalius, could I ask what is the closed length of your actuators and what is the extension lenth?
  4. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,034Coins
    3DOF, DC motor, Arduino, 6DOF
    I Vitalius. Long time since I saw where you where at. I checked your videos. That beast is going well. I hope you are having fun on it.
    I'm looking forward to play Elite on mine, but the platform has not the controllers installed on it, yet...
    Keep on the good work!
  5. hannibal
    4,491Coins
  6. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,034Coins
    Me too. Maybe in 2 weeks, when will reach the middle of the scholar session.
  7. hannibal
    4,491Coins
    with all the epxoy that you been working with, i been meaning to ask, how do you epoxy your carbon fiber tubes to attach the hiem joints / tie rod ends?
    i worry that epoxy will drip inside the tube..
    if you have a method for this, i would love to hear!
    that is the only thing i have to do with my actuators...
  8. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,034Coins
    I'll answer on my thread so we don't pollute Vitalius one.
  9. Vitalius
    Bonn
    540Coins
    all good friends. I'm back. I do not mind if someone spreads out here :).;)
  10. Vitalius
    Bonn
    540Coins
    Hi, I have to search my drawings to answer your question. I need a little time for that. Was not in project for a long time.
  11. Vitalius
    Bonn
    540Coins
    [QUOTE="I am not so good at SketchUp and can not afford it[/QUOTE]
    There is a free version of Sketchup.
    It means Sketchup Make.
    (If I understood you correctly.)
  12. Vitalius
    Bonn
    540Coins
    Hello everybody.
    Has anyone already experience with the AMT102-V encoder?
    I would like to use an AMT encoder instead of a potentiometer.
  13. Gadget999
    12,053Coins
    How many pulses per revolution does it have ?
    Are you using smc3 code ?
  14. Vitalius
    Bonn
    540Coins
  15. Vitalius
    Bonn
    540Coins
  16. Gadget999
    12,053Coins
    you will need to convert the code to work with encoders instead of potentiometers
  17. Vitalius
    Bonn
    540Coins
  18. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,034Coins
    Only 2 rods to support it all? You are a wild one.
  19. Vitalius
    Bonn
    540Coins
    [QUOTE = "Pierre Lalancette, Post: 215910, Member: 23761"] Only 2 poles to support everything? You are a wild one. [/ QUOTE]
    Hello, actually the rods are supposed to avoid the rotation of 1605. The entire weight should be distributed over the motor to the 3 mm thick aluminum tube on top and the recirculating ball screw 1605.
    Capacitive proximity switches Sensor Switch are to come tomorrow from amazon. Let's see how well they work with Kangaroo Kangaroo
  20. Vitalius
    Bonn
    540Coins
    Hello everyone, does anyone have experience with inductive proximity switches? I would like to connect inductive proximity switches to the Kangaroo x2 Motion Controller. Unfortunately I couldn't find any examples in google up to
    now, maybe a resistance has to be switched in front of it? I then search further :-(
    I am thankful for every help
