Showroom Building my first 2DOF (without welding or a steel frame)
Discussion in 'DIY Motion Simulator Projects' started by Brie69, Jul 3, 2018.
  1. Brie69
    Brie69 Active Member
    Beverwijk
    2Coins
    Ignition lock built in
  2. Brie69
    Beverwijk
    2Coins
    Now I am busy with the airflow through the space of the electronics.
    This space has since become a lot smaller because the entire sim has been lowered by 30 centimeters.
  3. Brie69
    Beverwijk
    2Coins
  4. Brie69
    Beverwijk
    2Coins
    After a while of not working on the sim I started again.
    I have purchased a new 32 "monitor for the sim which only does not have a Vesa mount to attach it to the steering column of the sim.
    Fortunately but otherwise it would not have been a challenge for me :)
  5. Brie69
    Beverwijk
    2Coins
    Here are a few photos of the rough carpentry.
    Apply a thin layer of MDF over this woodwork so that all screws and bumps disappear.
    Then sanding, filling, sanding, filling, sanding, priming, sanding, spraying, sanding, spraying, sanding, spraying.
  6. Brie69
    Beverwijk
    2Coins
    Meanwhile in the Netherlands......
  7. Brie69
    Beverwijk
    2Coins
    Making my own, stable Vesa mount bracket thingy....watching the paint to dry
