Mdbox 4DOF need help
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by JasonHim, Aug 3, 2019.
  1. JasonHim
    JasonHim New Member Gold Contributor
    186Coins
    Hi everyone, newbie here and motion system.
    Recently got a set of Mdbox nano 4 actuators from PT-actuator, with using simtools 2.4.
    I have set everything up, all actuators works with pressing button on nano controller, but I can't make it move in simtools output testing, there are only 2 com port detected (1 & 7), both tried with no help, factory side seems cannot help me on it, so I try to ask here.......
    And one more thing, I am using SC2 pro, I found that SC2 pro and the motion cannot work together, I can run SC2 smoothly, but it will disconnected once I fire up my motion.......
    So many issues here, can anybody help me on some of them ? I am so sad with the situation now.....
    Thank you everybody.
    145,124Coins
    +10,779 / 52 / -2
  3. JasonHim
    186Coins
    Here are the photos that I can show for all of you now, it is mdbox with using nano controller, I can test the motion by pressing buttons on controller, but no response from simtools.
    What else should I provide for better analyse the issue ?
    145,124Coins
    +10,779 / 52 / -2
    I am presuming you are using @Thanos AMC controller, is that correct?
  5. JasonHim
    186Coins
    Should be, PT-actuator told me to choose that option in pull down menu.
  6. JasonHim
    186Coins
    Is there any log function that I can check for any clues ?
  7. JasonHim
    186Coins
    Today I test it in Assetto Corsa with practice session.
    It works for many laps that I drive, but once I back to menu and start another session, the motion stop again.
    Is there any clues ?
  8. Thanos
    Electronics Engineer
    2,699Coins
    Run the AMC configuration tool, and tell me what firmware version you see... perhaps it needs upgrade to v2.00...
    https://github.com/tronicgr/AMC-NANO_Firmware/blob/master/AMC_Config_Tool.zip
  9. JasonHim
    186Coins
    Hi Thanos, thanks for your information, will let you know later today, I’m not close to my rig now.
  10. JasonHim
    186Coins
  11. Thanos
    2,699Coins
    Did you try to "open" the port to see if it connects to the controller?
  12. JasonHim
    186Coins
    Tried, no reaponse
  13. JasonHim
    186Coins
    With few more clicks, opened but without any information there
  14. Thanos
    2,699Coins
    Just follow the instructions to load the latest firmware... It won't open if you have old firmware.
  15. JasonHim
    186Coins
    may I know where is the instruction ? I just see few screen captures inside the zip file but not instruction.
  16. Thanos
    2,699Coins
    Check your email
  17. JasonHim
    186Coins
    it don't have anything new there....
  18. Thanos
    2,699Coins
    Check your spam folder perhaps...
    Anyway.
    Download the bootloader utility here:
    https://github.com/tronicgr/AMC-NANO_Firmware/blob/master/Firmware bootloader Utility 52.zip
    and download and unzip the latest firmware from here:
    https://github.com/tronicgr/AMC-NAN...r/Latest_firmware/enc_4dof_AMC-NANO_v2_01.zip
    To see the version of the firmware use the AMC config tool here:
    The config tool can be used to set some things like park position and speed and number of motors used etc. This tool was created to replace the LCD menu
  19. stashy
    stashy Member Gold Contributor
    india
    - 238Coins
    2DOF, SCN6
    hi thanos ran the config tool im in firmware v2.00,having the same issue
    ok followed your youtube guide and updated to 2.02
    the physical buttons on the controller makes the actuator move but in simtools not able to get any movement
  20. Thanos
    2,699Coins
    There has been some updates... see below.
    First make sure you have the latest version FTDI drivers installed:
    https://www.ftdichip.com/Drivers/CDM/CDM v2.12.28 WHQL Certified.zip
    Load the latest firmware here:
    https://github.com/tronicgr/AMC-NAN...r/Latest_firmware/enc_4dof_AMC-NANO_v2_02.zip
    Firmware procedure video for AMC-NANO:
    (short version)
    (full length version)
    You can use the latest v1.1 config tool to access and modify the parameters in the AMC-NANO:
    https://github.com/tronicgr/AMC-NANO_Firmware/blob/master/AMC_Config_Tool_1_1.zip
