Showroom New DIY 3DOF dynamic workstation project UPGRADE 4DOF
Discussion in 'DIY Motion Simulator Projects' started by Milani Fabio, Feb 27, 2019.
  1. Milani Fabio
    Milani Fabio Active Member
    Italia
    714Coins
    work in progress….
    Prototype
    Definitive
    I bought a cube case for PC .....Itek QBO 8
    I modified it and I inserted all the electronics, which will be positioned in the center of the motors.
    20190520_182138.jpg 20190520_182218.jpg 20190520_184112.jpg 20190522_101143.jpg
  2. Milani Fabio
    Italia
    714Coins
    More photos with the case assembled and mounted in its place.
  3. Sean Thompson
    Sean Thompson New Member
    193Coins
    Thanks man, Now I can at least begin looking at the room I want to put it in and making this happy.
    Final base build looks EPIC!! If you happen to have a CAD/Sketckup of this Please do share, as so far Looking at basing mine very heavily off yours.
  4. Milani Fabio
    Italia
    714Coins
    Thanks sean,
    I don't use software for design or mechanical design, only manual.
    This is my CAD / scketchup ...…….:blush:blush:blush :arrow:think:!:!:!:D
    • Funny Funny x 2
  5. gigi
    gigi Active Member
    900Coins
    2DOF, JRK, 4DOF
    Nice work!
  6. Sean Thompson
    193Coins
    Well I cannot fault it since this sim looks epic! I've broken the Tape measure out and already beginning designing mine based off your Measurements.
  7. FrancescoRoberto
    FrancescoRoberto Member
    Italia
    106Coins
    H
    Hello Fabio,
    It's a beautiful work your playseat.
    I'd like to know how did you buy the Transtecno motor, because I didn't succeed. I don't have "Partita I.V.A. "
    Best Regards
    FrancescoRoberto
  8. Milani Fabio
    Italia
    714Coins
    Ciao Roberto, Transtecno does not sell to private individuals, you must support a friend with a partita IVA.
    I did so.
    The Transtecno engines are a bit expensive compared to the Chinese ones, everyone told me this.
    Call Transtecno and ask for Cinzia Solitro, I have dealt with her.
    Hello
  9. Milani Fabio
    Italia
    714Coins
    Hi guys,
    Cause transfer of the workshop location ....... grrrrrrrrrrrr :mad::mad::mad::mad:...... after 50 days the pieces I had ordered arrived.
    These are the supposed anchors of the upper base.
    In the coming days I paint them and put them together.
    Then I will do a movement test like the one in the previous post with the prototype wood.
    Hello
  10. Milani Fabio
    Italia
    714Coins
    Here is the top laser cut base.
    Despite many holes to lighten it the weight is 12 kg ..... I thought less …
    20190610_150836.jpg 20190610_150855.jpg 20190610_150921.jpg 20190610_151727.jpg
  11. Milani Fabio
    Italia
    714Coins
    The structure with seat, steering wheel support and pedals is also finished
  12. Milani Fabio
    Italia
    714Coins
    Last test for the mechanical part to verify that when the base is in the lower part, it does not touch the electronics case
    • Like Like x 6
  13. Horker
    Horker New Member
    174Coins
    Hi Fabio. I hâve thé sale project, but i dont use Sabertooth. I use Cytron and there is no régénératrice protection. So i will use 2,2kohm résistance in parallele of Power supply.
    Where do you your lever?
  14. Milani Fabio
    Italia
    714Coins
    Sorry for my English ... I use the translator ...
    When you say "lever" do you mean potentiometers?
    I have not yet mounted the potentiometers, it was just a mechanical movement test to see the dimensions.
    The potentiometers will be mounted like this:
  15. Horker
    Horker New Member
    174Coins
    My english is worst, sorry. Lever can be translate by crank.
    Do you buy it or you do it yourself?
  16. Milani Fabio
    Italia
    714Coins
    The crank cannot be bought.
    The dimensions are my project, built with a cnc machine in ergal material.
  17. Milani Fabio
    Italia
    714Coins
    I brought everything home and assembled the upper base and the seat.
    Now is the moment of truth ..... Sim Tools .... Arduino .... Sabertooth.
    I have to start studying to understand all the software ....
    We hope everything goes well.
    20190619_121645.jpg 20190619_121658.jpg 20190619_121728.jpg 20190619_122148.jpg
    The aluminum frame for the steering wheel and pedals is also ready, which I will install after the softwere tests …
  18. francois38200
    francois38200 Member
    vienne
    195Coins
    realy nice project :thumbs
  19. momoclic
    momoclic Active Member
    Retraité
    Nantes - France
    2,761Coins
    DC motor, Arduino
    Excellent and nice work!
  20. hannibal
    hannibal Active Member
    4,489Coins
    i wish my reference sheets look that good...my design is scratch written on paper with pen..
