Direct Drive Stepper Sim Wheel
Discussion in 'DIY peripherals' started by psndu, Apr 29, 2019.
  1. psndu
    psndu Envizzion
    Sri Lanka
    192Coins
    Hi All .Its been several Months since I discovered the world of DIY simulators and as of now I 've build a traditional sim wheel rig with a DC motor based on racingfr's firmware for arduino leonardo . It was working great actually it was the best wheel for me at the time but with time i realized the wheel is still missing those finer details from the games .So after a long research being a budget guy i had only two options
    1. DC motor sim wheel with more Power.(i only have one dc motor)
    2.Direct drive Wheel with Stepper Motor (got lots of nema24 s)
    Since my aim was the finer details and being more of a software guy (it was a nightmare building those gears for my first wheel) the obvious choice was the Stepper. Thanks to the great post 'Son of Open Sim wheel'
    by RufusDufus I had a great starting point. Before you read further i reccommend you to go through his thread because I won't be explaining the basics.So Let's start.
    COMPONENTS
    Stepper Motor
    Since I'm still experimenting i'm using a nema17 .The major requirement is the motor should have at least 1.8 degrees per step .
    Encoder
    at least a 2000 ppr(points per revolution) encoder . I'm using a scrapped optical encoder from a printer .
    Software
    the Racingfr's wheelConfig which is ported for arduino leonardo .Also the MMos firmware for stm32 can also be used ,they both has the same outputs for pwm /dir which i'll be using in my controller.
    Theory and application notes
    Theory in Simple terms is 'Closed loop current control of stepper motor' .
    A general Stepper motor is rotated by excitation of its two windings in sequence of steps .each step makes the motor rotor turn 1.8 degrees .being open loop after each step we don't know if the rotor has moved 1.8 deg so after each step a delay is maintained allowing the rotor to move its angle.the stepvise movement in stepper we see is due to the rest time which the rotor spent at rest waiting for the next step to occur.So by applying closed loop control we find the no. of encoder positions the rotor moves for each step .Then when one step is applied we can continue to monitor the encoder and apply the next step just before the rotor completes its motion so that rotor never gets a chance to rest and we will not see or feel the steps.The reason to go with current control is to archive better torque control .
    1. L6506 current controller and DM001 application note for microstepping ( thanks to Nerd+'s post on SOSW thread )
    2.A Simple Algorithm for Closed-Loop Control of Stepping Motors (Research paper).
    3. atmega328 pin change interrupts and input capture ( for pwm/dir and encoder capturing)
    PROGRESS SO FAR
    After working nonstop for like three weeks I think I got it to work with some minor issues ,may be due to my lazy encoder placement.But in overall It is ok I guess. I still have everything in prototype mode and will post the necessary files when they are ready.
    The prototype (the red driver is an a4988 driver(my first try) and it was't used in the project)
    on left end is the L6506 set in fast decay mode
    on right end is the dual H bridge for driving the stepper.
    Arduino leonardo is for the RacingFr's AiWave firmware and uno for the handling pwm and controlling the stepper
  2. ahoenksiluman
    ahoenksiluman Member
    indonesia
    89Coins
    interesting project....
    why you dont try dual hbridge modul L298N..??
  3. psndu
    psndu Envizzion
    Sri Lanka
    192Coins
    I did use the l298 but since its transistor switched the internal losses are much higher .And it was always running hot .
  4. ahoenksiluman
    indonesia
    89Coins
    what type is your photoelectric for your encoder..??
    are u using regular photoelectric for printer disk..??
  5. psndu
    psndu Envizzion
    Sri Lanka
    192Coins
    No complete unit is taken from a printer
  6. psndu
    psndu Envizzion
    Sri Lanka
    192Coins
    Centering Demo .
  7. psndu
    psndu Envizzion
    Sri Lanka
    192Coins
    Its Almost Ready Now.Need to move to a bigger motor for further testing.
    Test with Euro Truck Simulator (Sorry for the sound ,it was raining)
  8. llluis
    Quebec
    1,630Coins
    Your H bridge is rated for how much current?
    My Nema34 is rated at 5A (13Nm).
    Nema42 can be 6A (22Nm) or 8A (30Nm).
    If the bridge can handle that it would be very interesting.
  9. psndu
    psndu Envizzion
    Sri Lanka
    192Coins
    It uses mosfets rated at 12Amps continuous .Since we are switching to control the current they will do more than 20Amps .But the issue is the motor ,I'm trying to find a nema34 at least let's see.
  10. psndu
    psndu Envizzion
    Sri Lanka
    192Coins
    new Setup with nema23 .still testing at 12v 1Amps
  11. ahoenksiluman
    indonesia
    89Coins
    you should test it with wheelcheck (step log 1, 2 and 3) and share the log file, that would be interesting...
  12. psndu
    psndu Envizzion
    Sri Lanka
    192Coins
    Thanx I'll do it. But i accidentally damaged the encoder disk .So I'll Have to pause the project for a while.
  13. Kosta100
    Kosta100 New Member
    23Coins
    I am also trying to build a dd wheel using a nema 34 stepper motor. My plan is to use tb6600 or something similar and replase its pot, which is used for current limiting, for a digital one. I have aquestion for you, do I need to control both torque and rpm, or just torque?
  14. Kosta100
    Kosta100 New Member
    23Coins
    Also why is your wheel shaking so much?
  15. Ben Xie
    Ben Xie New Member
    70Coins
    Arduino, 6DOF
    Can you feel the steps in the stepper motor? Is it smooth? I was thinking of doing the same thing.
    Thanks!
  16. HCR Mad Bull
    HCR Mad Bull Member
    439Coins
    DC motor, AC motor
    Hello, I'm very interested in this, do you have any updates for us with this project?
  17. tassault
    tassault New Member
    78Coins
    Hi, Can you share your wiring configuration and the code for Arduino please ?
  18. PMonteiro
    PMonteiro New Member
    40Coins
    DC motor, Arduino
    I am trying to build using L298N, but something is running bad and i dont know what. I am using the "ffbwheel.0.16.leonardo.hex" on a leonardo. But I dont know the correct way to connect the driver, neither about my encoder config (using NY-20 + 1k resistor to A and B, connceted to Vcc). But something is running bad. Didnt see ffb working. Not yet.
    When i connect usb, motor starts low speed (tonone direction) and stop. Dont see it working no more.
