Question Saber 2x32 Voltage clamp, automatic or 12v?
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Trigen, Apr 20, 2019.
  1. Trigen
    Trigen Active Member
    2,872Coins
    Wondering if these should be set to 12v or automatic. When i got it on automatic the resistors dont get especially hot. If i set it to 12v they get smoking hot, melts the heat glue.
    The docs for the sabertooth is rather lacking.
  2. BlazinH
    16,665Coins
    Honestly so is the info in your post. Define "these".
  3. Trigen
    2,872Coins
    Voltage clamp, its in the title
  4. BlazinH
    16,665Coins
    I wasn't sure if you meant power supply or tooth because tooth doesn't list those settings in manual. You must mean in Describe then. Don't know I don't use it.
  5. BlazinH
    16,665Coins
    I would try around 14 volt though.
  6. Trigen
    2,872Coins
    No worries and I'll make sure to be more specific in the future.
    Gonna give 14 a go
