6DoF VR Flight Pit
Discussion in 'DIY Motion Simulator Projects' started by Historiker, Feb 18, 2019.
  1. Historiker
    9,208Coins
    Thanks for the heads up, but without deadzone added the motors bounce back and forth like crazy.
  2. Historiker
    9,208Coins
    It will be a few days before I can get back to the project and hook up the electronics again. I did get something done today though:
    As you can see, I made a slight math error. My motors are too far in, I do not have any angle to the connecting rods. I might (ok, will have to) move them out and add a bit to the outer edge for mounting holes.
  3. SilentChill
    20,592Coins
    Is that not be because you have the pwmmin set at 50 ? Just a thought , what ever works I guess :thumbs
  4. Historiker
    9,208Coins
    Would that cause it? I will check it out tonight, thanks Craig!
  5. Historiker
    9,208Coins
    @SilentChill I will be in Europe this summer, and there is a small chance that I will be in your neck of the woods in June and if I am I will find you and give you a giant hug! No wobblies with zero Pwmmin!hug:
  6. Historiker
    9,208Coins
    The rig is up and running. Manual movements are great, or seem so. Just need to work on syncing all DoFs right now. They all seem to work though. Nifty :)
    Tried the DCS plugin but movements are jerky and not coordinated. There is some amount of Saberteething to expect though :D
  7. BondeX
    BondeX Active Member
    EE
    Michigan, USA
    1,501Coins
    Video Please please please....
  8. Historiker
    9,208Coins
    Soon :) The movement is still very twitchy, working on that now.
  9. Historiker
    9,208Coins
    Fixed the jerkiness (is that a word?) by increasing PID to 4. I will try reducing it one step at a time to see if a lower value works as well.
    Really, everything I am learning is from @SilentChill 's posted experience. Really need to hunt him down and give him "the hug" :D
  10. Historiker
    9,208Coins
    MOTION!
    Movement is a bit jerky due to my ability to slide the little...er...sliders back and forth :)
    Oh, I did do a test with me sitting on it. A couple of things....ouch and Ouch! :D Surge and sway are very very very quick.
    • Like Like x 6
  11. Historiker
    9,208Coins
    Now I just have to mount my seat, arms, rudder mount.....those things.
    Also did some testing in X-Plane 11 and DCS, both worked pretty well. Still need some fine tuning but I am impressed.
  12. SilentChill
    20,592Coins
  13. Historiker
    9,208Coins
    I downloaded that yesterday but have not yet gotten around to playing with it. I did read the thread though
  14. Historiker
    9,208Coins
    No work will be done on the rig tonight....its my wife's birthday....er...kind of forgot about that. Shhhh, dont mention that to her :D
  15. SilentChill
    20,592Coins
    You got it moving nicely so shes allowed some of your time :D
  16. Historiker
    9,208Coins
    It's ALIVE!!!!
    Pretty much finished. I still need to install the 12v relays; 30amp for the power supplies and a 200amp main for the battery to the Saberteeth.
    Spent a hour or so flying around in DCS, motion is a bit jerky/grainy but I have not played around much with axis settings/smoothing etc. I did test motion with PID set from 1-4 but did not feel a difference. Need to work on the smooth start settings as well. When I flip between game window and Simtools settings it makes a wild jump back to center each time. Hopefully I can get this movement less violent ;)
    The base steel frame in all its glory (picture Vana White waving her hand)
    A comfy office chair mounted on the frame to form around my rear...aspect. The stock mounting system is very handy for this. And I drilled many holes to adjust my CG just in case my calculations are off. (They did not seem to be!)
    I added a board between the seat and the frame so I could adjust height/angle, etc.
    • Winner Winner x 3
  17. Historiker
    9,208Coins
    Not the greatest video, I had asked my wife to keep the motors and the base in the shot but she got distracted with our dog. The majority of the video only shows the floor and paws :D
    I did take a video of her riding the roller-coaster but after the expletives that she used I was advised not to publish it :p
    Still need lots of tweaking and fine tuning. I have 15% smoothing on all DoF but I am thinking of reducing this further.
    Borrowed the power supplies off the 3DoF to augment the two 30amp LED power supplies. I am thinking of making both rigs work off shared resources like power supplies, saberteeth, etc.
    • Like Like x 5
  18. CBC_North
    CBC_North Member
    Computer Engineer
    Ottawa, Canada
    333Coins
    Looks great. Jealous of your simulator cave AND your shop.
  19. Historiker
    9,208Coins
    Here is my wife's ride, colorful language removed...well...most of it :D
    • Funny Funny x 2
  20. Historiker
    9,208Coins
