Question Miniature motion platform
Discussion in 'DIY Motion Simulator Projects' started by Kenza, Mar 5, 2019.
  1. Kenza
    Kenza New Member
    126Coins
    Hello everyone ! I hope you're having an excellent day.
    So, instead if working on a 3DOF flight simulator I decided to start with a miniature motion platform in order to understand how it works before starting the project..
    The miniature is much more simple and practical.. However, I was hoping to get more information about the control part. Is it possible to use the same wiring (Arduino+MonsterMoto) and arduino code (SMC3) ?
    I will be using small servos btw, and simtools of course.
    Thanks a lot !
  2. bixler13
    bixler13 Member
    107Coins
    I just made a mini platform to test simtools with mini 9g servos. You wont need the MonstorMoto for the servos as they can be powered and controlled via PWM directly from the arduino itself. Depending on the size of the servo you might need to add external 5v power, but if they are little 9g servos you should be okay just using USB power.
  3. bixler13
    bixler13 Member
    107Coins
  4. Kenza
    Kenza New Member
    126Coins
    @bixler13 THANK YOU SOOOOO MUCH it really helped !!! I will test the results I've found as soon as I can and keep you guys updated !
  5. Kenza
    Kenza New Member
    126Coins
  6. Kenza
    Kenza New Member
    126Coins
    BIG THANKS TO @eaorobbie, @aarondc and @Jun for making things possible for me ! You rock guys !
    This is what I'm going to test.
  7. Wilson Rios
    Wilson Rios New Member
    473Coins
    Thanks a Million Kenza!
    You are the only person that provide complete and correct working directions here.
    Most of the other threads have either pre-history and incorrect directions, or for the most part people providing bits of information, so you have to guess the rest.
    Thanks again for taking the time sharing it, and I hope I come across with more people like you in the forum!
    Cheers!
  8. Kenza
    Kenza New Member
    126Coins
    You are very welcome ! I'm glad you found my thread interesting ! :thumbs
    BTW I did it ! I only need to test the program.. I will keep you updated.
