Servo Commander Problem
Discussion in 'XSimulator Q&A/FAQs - Outdated' started by Yoshi, Jul 17, 2009.
  1. Yoshi
    Yoshi New Member
    0Coins
    Hey!
    I am a new member of this board and i just started to plan a 2 DOF sim. :hi:
    For the beginning I wanted to learn all the functions of Profiler 2.0.
    So i started with the Gauge setup. Seemed easy but now i have a problem.
    Profiler --> Servo Commander
    Now i have the Problem that all 8 PWM Signal are on one Soundcard output. I tested the signal with an oscillator.
    one Output: 8 PWM Signals
    remaining 7 Outputs: No Signal
    Anybody an idea? :sos:
    Soundcard is a Realtek High Def Audio Onboard.
    I added a picture. It's the fist construction and not a final version .
    Greets Yoshi
  2. RaceRay
    Hamburg, Germany
    23,884Coins
    Hi and welcome here :)
    In the Realtek driver settings you are able to determine if stereo or multi-channel outputs should be used. When you connect speakers does the sound comes out from all speakers or only two of them?
    I think it must be set up to one of 5.1 / 6.1 or 7.1 output.
    I never used the sound card controlling before, so it is only a assumption.
    regards
    René
  3. Yoshi
    Yoshi New Member
    0Coins
    Thank you for your idea.
    But the settings are 8 Channel and i just tried 5.1 and 6.1 too.
    Doesn't work.
    I will test it on a another PC next week and report the results.
    greetz Yoshi
