Showroom Budget Steel 6dof w/ MM (Now Sabertooth 2X60), Arduino, Chinese 12v Motors
Discussion in 'DIY Motion Simulator Projects' started by CLEOPHUS, Sep 3, 2016.
  1. CLEOPHUS
    CLEOPHUS Member
    229Coins
    I would run from MMs. Only go with the sabertooth. They are more $ - but you'll be spending it sooner or later anyway. 500w seems to be overkill - especially for a 110v outlet. They would take 42Amps to power and you would have spikes in the neighborhood of 100a. Technically - the sabertooths can handle 60a and spikes up to 120a.
    The 350w motors have held up great. Would buy them again.
  2. jakestevens
    jakestevens New Member
    Technician
    Tennessee
    129Coins
    Where did you get the 12vdc motors and gear boxes?
    Did you order the shafts separate?
    I ordered identical motors and gearboxes from ebay, the shafts are hollow. I had to tap the I.D. of the shaft to get any sort of length from the unit.
  3. CLEOPHUS
    CLEOPHUS Member
    229Coins
    There is a link in the first post. Both the motors and shafts were ordered together from Alibaba. (Dake Motor co.)
    Thanks,
    Cliff
  4. jakestevens
    Technician
    Tennessee
    129Coins
    I can't believe i looked over that.
    Thank you!
  5. hannibal
    hannibal Active Member
    4,491Coins
    do you have a direct actual link to the motors you purchased? you first post brings you to the company supplier page, but there is so many motors of the same type, alilbaba is confusing! appreciate info!
  6. CLEOPHUS
    CLEOPHUS Member
    229Coins
    Dake motor doesn't advertise these motors. You'll just need to contact them and request them. They custom build everything.
  7. hannibal
    4,491Coins
    didnt realize as most of the DIY's i have noticed try to buy from surplus or regular stock!
    thank you! hope you are spending time with your build.. i enjoyed your youtube videos, i see your son is champing! driving like boss!
  8. CLEOPHUS
    CLEOPHUS Member
    229Coins
    Dake Motor was super easy to work with and I would definitely recommend them. If you can find the right motor via surplus, that would be great too, I just couldn't find the right combo that I needed in surplus, and if I could, I then couldn't find 6 of them. Good Luck
  9. SimMeInMD
    SimMeInMD Member
    Baltimore MD (USA)
    266Coins
    @CLEOPHUS,
    What are the specs on the gas springs? Thanks!
  10. CLEOPHUS
    CLEOPHUS Member
    229Coins
  11. SimMeInMD
    SimMeInMD Member
    Baltimore MD (USA)
    266Coins
    Thanks @CLEOPHUS, going to purchase 3 tonight.. Did you notice any negatives as far as motion once you installed them? Slower -heave, roll was dampened, etc?
  12. CLEOPHUS
    CLEOPHUS Member
    229Coins
    100% positive impact. Smoothed everything out and eliminated the neck pain after using it for 30 minutes. You absolutely need them.
  13. anatachaikiet
    anatachaikiet New Member
    178Coins
    hello... what happened when you use MM ? and why change use sabertooth ?
  14. CLEOPHUS
    CLEOPHUS Member
    229Coins
    They would catch fire. Too much for them!
  15. anatachaikiet
    178Coins
    ok thank you.. but for me use MM because sabertooth high cost....
  16. CLEOPHUS
    CLEOPHUS Member
    229Coins
    Spend the money now or spend it later. But I guarantee you'll spend it!
  17. anatachaikiet
    178Coins
    you give me link to sell sabertooth 2*60 ?...
  18. SimMeInMD
    SimMeInMD Member
    Baltimore MD (USA)
    266Coins
    @CLEOPHUS …. Look like something yove seen before? :)
  19. CLEOPHUS
    CLEOPHUS Member
    229Coins
    Just awesome. Sorry I didn't see this earlier. Please post an update. Moved and just getting the sim set back up!
  20. RacingMat
    21,050Coins
