Dirt Rally 2 Plugin v2.3
SimTools plugin for Codemasters Dirt Rally2
  1. yobuddy
    51,535Coins
    yobuddy submitted a new resource:
    Dirt Rally 2 - SimTools plugin for Codemasters Dirt Rally2
    • Like Like x 12
    • Winner Winner x 7
  2. ESMO15130
    ESMO15130 New Member Gold Contributor
    15Coins
    2DOF, SCN6
    bonjour et merci pour le plugin de dirt rally 2.0.
    • Dislike Dislike x 1
    153,884Coins
    +11,154 / 57 / -2
  4. leonaikikai
    leonaikikai Member Gold Contributor
    45Coins
    Hi Mister Yobbudy many thanks for your works
    hug:;););)
  5. michael münscher
    michael münscher New Member
    Germany Thüringen
    45Coins
    thanks
    Great work
  6. Hamreus
    Hamreus Member
    Avesta
    666Coins
    2DOF, SCN5
    Thank you so much!
  7. yobuddy
    51,535Coins
    Anyone have the console version of the game they want to test with a rig?
    If so, just buzz me and I can make a test version for consoles also.
    Take care,
  8. Doctor Kruntz
    Doctor Kruntz Active Member
    400Coins
    3DOF, SCN6
    GREAT and faster work... yobuddy Number ONE!
  9. HoiHman
    HoiHman Active Member
    Mechanic
    The Netherlands
    332Coins
    Great work and thanks
  10. Majony
    Majony Member
    54Coins
    SCN6, 4DOF
    For consoles? how its it?
  11. L.Dörenberg
    L.Dörenberg beginner Gold Contributor
    car bodyrepair
    Netherlands
    - 65Coins
    WOOW! i wanted to ask if someone would like to make a plugin for this already highly recomended rally game.... but there comes superman Yobuddy, Thanks alot!:thumbs
  12. titomaky
    titomaky Member Gold Contributor
    181Coins
    Motion platform
    Thank for you
  13. BlazinH
    16,690Coins
    I believe all Codemasters titles uses a somewhat uniform method for data extraction so that makes things a little easier when the next title rolls out.
    • Disagree Disagree x 1
  14. titeufgamour
    titeufgamour New Member
    79Coins
    bonjour, je DirtRally2_GamePlugin.zip téléchargé et installer Outils Sim, comme d'habitude. il ne figure pas dans la liste des outils Sim. J'utilise Outils Sim v1.3. J'ai essayé avec des outils Sim v2.3.1 il n'a pas dans la liste aussi. J'ai oublié comment le faire. Quelqu'un peut-il m'aider? Je vous remercie
  15. ilbiga
    ilbiga Active Member
    Network Engineer
    103Coins
  16. titeufgamour
    79Coins
    Oui désolé, je résolu mon problème! il fonctionne très bien. excellent travail ... Merci
  17. Kranky Pantz
    Kranky Pantz Active Member
    Canada, Eh!
    1,288Coins
    Sachez que vous pouvez publier deux langues, mais cela fait partie des règles du forum que vous incluez également l'anglais. Le faire via Google Translate est correct.
    https://translate.google.com/?hl=en&tab=TT#view=home&op=translate&sl=auto&tl=en
    "ilbiga" I've translated your advice into French, as I don't think that "titeufgamour" understood what you were saying.
    Hopefully they'll understand now.
    So, how is DiRT Rally 2.0 with motion folks?
    I missed the window of when the plugin was first posted in the forums on Friday, then moved over to the plugins section. :(
    Since it's the only one I need, I don't want to use up a weeks worth of downloading privileges, as the plugin may break once they release this big "Day One" patch which is supposed to be coming shortly to fix FFB issues and a lot of other problems.
    Just got the game today, it looks fantastic.
    Motion + TrackIR will make it enjoyable until VR is patched in the Summer. :popcorn
  18. Youngsoo Cho
    Youngsoo Cho VR Sim Racing Gamer
    Business Man
    Korea
    467Coins
    I will wait until they update vr support :D hope that there will be vive support too. not only rift
  19. fredopipo
    fredopipo New Member
    - 55Coins
    comment as tu fait car chez moi ca ne semble pas fonctionner. Merci
    153,884Coins
    +11,154 / 57 / -2
