  1. marco balletta
    marco balletta Member
    1,445Coins
    Can anyone please tell me if it is normal that all these axes move this much when the car is not moving and also some are not in the center ?
  2. marco balletta
    1,445Coins
  3. Javo5
    Javo5 Active Member
    Buenos Aires, Argentina
    300Coins
    Same question
  4. marco balletta
    1,445Coins
    The p3 setting is way less complicated than the p6.
    Look at the screencap
    The h6/p6 axes setting is much more complicated than the h3/p3 setting.
    See attached screen captures
  5. Benji85
    Benji85 Member Gold Contributor
    851Coins
  6. Javo5
    Javo5 Active Member
    300Coins
    Does anyone know the difference between M2 and MS2 seat mover?
  7. marco balletta
    1,445Coins
    Show us a 6 dof that looks good and different that the 6p and that you and the majority can afford buying
  8. Benji85
    851Coins
    No mean the movement looks bad. Did you tune it ect?
  9. splendiddd
    splendiddd Active Member
    CCTV security
    Netherlands
    812Coins
    No its not normal, Try to patch the game again, and/or check the hardwaresettings config file in your documents/mygames/dirt3 folder.
    I had similair problem with dirt 3 in the past. Also, remember that the game motion goes away after one run, you need to run a special program to avoid that.
    Use this little program
    https://www.stryder-it.de/simdashboard/help_dirt3crash.php
  10. splendiddd
    CCTV security
    Netherlands
    812Coins
    I understand, but i don't have the P6 so sorry cant help there.
  11. marco balletta
    1,445Coins
    I wish I would be capable to tune the p6. This is the help I am looking for from who would update from p3 to p6.
    If you look at the attached screencaps, how do those settings look compared to a p3 ?
  12. Benji85
    851Coins
    So they not send it out with any presets? How do they test it properly without?
  13. marco balletta
    1,445Coins
    For the 6p/6h , there are presettings for 2 games .
    But the question is how do you judge that the movements of the h6/p6 being good or bad from a video that does not show the gameplay with the movements of the p6/h6 that are a consequence of that gameplay?
  14. marco balletta
    1,445Coins
    I will try your suggestions this weekend. Thanks for your hint about dirt 3 !
  15. Benji85
    851Coins
    It was just an observation. Does it feel great then to play? Or am I correct?
  16. splendiddd
    CCTV security
    Netherlands
    812Coins
    Just remember to also use the tuning center ;-) and go one DOF at a time
  17. splendiddd
    CCTV security
    Netherlands
    812Coins
    I had the same issue, emailed DOF and got thicker replacements without any discussion.
    I must say, customer service is great !
    Here are some pics
  18. Benji85
    851Coins
    Yes I agree they are really helpful
  19. ChilliPepper
    ChilliPepper New Member
    217Coins
    Hello all, Im new to the forum. After in-depth research with 3 dof motion platforms available on the market. I have decided to go with the P2 as hope to upgrade to the P3 later. The platform will arrive in 2 weeks from Ukraine to UK.
    I saw a thread in AC today mentioning there are problem with AC interacting with Dof reality platform, but that was an old thread from 3 months ago, has the problem been solve?
    153,065Coins
    +11,117 / 56 / -2
    More likely a DOFreality owner had not properly configured a motion profile, do you have a link to what thread your are referring to?
